White cloth insulated conductor = coil end, normally coil "hot"
Red plastic insulated conductor = permanent independent ground for metal baseplate (and other things)
Red to either pot chassis.
The order for the white and black conductors will depend on the magnetic polarity and output cable format of the bespoke Alegree 'Tron.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
https://i.imgur.com/8i2YrwG.jpg
Does this shed any light on it?
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
There is too much frayed cloth insulation around the solder joints on the volume pot to form any opinion on how good, bad or indifferent they might be.
Also check the jack - a totally dead guitar is most often caused by a short there than anywhere else.
Will get some pictures up shortly.
So here is the beast:
https://i.imgur.com/DcR0t9q.jpg?1
https://i.imgur.com/WfUUvk6.jpg?1
With body and neck from @caspercaster bridge pickup from @paulnb57 and generous donations of kit from each of them. Neck filtertron from @alegree together with various bits.
I'm still intending to put a 7.25 rosewood neck on it at some point and needs another go at setting it up but sounds brilliant and I wired it all myself from scratch which was a new experience. I can see why people buy pre-wired but I learned a lot.
Thanks to everyone for the considered wisdom and assistance!
