New tele has 'rings' - advice, please!
  • valevale Frets: 1052
    edited June 2018
    it's just a compressed concentric waveform pattern due to a lower bit rate than your tv is deisgned for.
    imagine a 2D straight undulating waveform line, then bracket sections off (each wave ring) to a single average value for that ring or wave (lowest to highest point, or cycle)
    then apply that to each wave radiating out from a centre point (in your case, brightest to darkest points of an image).
    if you take the max brightness point (centre point) of the image to be 100% and the lowest point (outermost ring) to be 0%, then for the innermost ring or band flowing out from the centre, imagine that all brightness values within that range (between 100% and 90%) will be averaged out to 95%.
    & so on.
    so for the next ring or band, all values between between 90% and 80% will be averaged out to 85%.
    so instead of getting a smooth transition between 100%-0% brightness to darkness (radiating out from centre point of max brightness), you get ten stepped or bracketed average values (95%, 85%, 75%, etc)
    yout tv isn't broken & i think any compensating algorithm that tried to smooth over that transition ridge between average value rings would make things look virtual reality smooth, not natural.
    hofner hussie & hayman harpie. what she said...
  • strtdvstrtdv Frets: 2468
    Isn't counting them how you tell the age of it?
  • ToneControlToneControl Frets: 12007
    it definitely looks like a compression artefact
    It's worth playing with the noise reduction and sharpness settings on your TV though
    the presets are often vicious, especially the ultra-bright, high-colour, high-contrast ones they use on display models in the shop
