As a microscopically accurate replica of tedious inconsequential details good enough to fool black light-equipped lab techs who can't even play a barre chord? Don't even go there.
A good R9 is an amazing thing, but like old guitars you can get some right dogs too. so realistically Id say search for a good les paul standard (regardless of R moniker) and enjoy it. Eventually it'll be 50 years old, dried out, played in and degaussed too.
In simple terms, it be better and more consistently built, but from slightly worse materials.
The R9 will likely play better and sound more like you expect a 59 too.
Instagram
No, hang on, it's not quite the same thing, I think Gibson are probably making an honest attempt to reproduce a product they once made before, hence the neck profiles change with the year, but they ain't using the same wood, so would you expect the guitars to sound the same?
I'd still like an R9 though.
its unlikely the issue
Water profiles are an important part of any beer recipe. I live in Burton, famous for our water, and the first thing we do is strip out every single chemical and remix it for the appropriate recipe. The process is called Burtonisation, as it was originally done to copy our natural water profile. Our brewing water is still drawn from the same aquifers as always
GK would not ignore the water profile, its an easy bit to get right. But they will likely make changes for other reasons (cost and mass market appeal are the normal culprits). Some breweries are just not as good at flavour matching as others and changing from one lot of equipment to another can cause variation even if everything else is exactly the same
Instagram
Interesting in that all original 1959 models are not exact DNA replicas of each other, partly/mainly due to the variation within a hand built instrument
There has been many blogs on FB about this, time after time and one or two members have all the appropriate info down to a fine art
As for the pick-ups - read this http://www.tonequest.com/files/TQRJan09_proof.pdf and pay attention to the final paragraph that say's
The truth is, no one may ever be capable of reproducing the exact tone, dynamic and vocal character, clarity, bloom and rich harmonics found in a great set of PAFs, which were, after all, essentially happy accidents created by the convergence of extremely varied and largely undocumented materials and components, assembled by relatively unskilled factory workers laboring with flexible specifications and imprecise equipment.
As for which to buy - Consider this - Gibson only built around 1,500 59 Les Pauls - Only about 3,000 are still in existence ! - With prices in excess of 100K and beyond, then most of us are grateful that we can buy a good R9 from around £3500/4000 on wards - Is it as good, maybe, maybe not, but they have reduced the differences regarding how the guitar performs, so much so that the needs of most are satisfied by a good replica
Granted Gibson have made regular tweaks to their 'best ever' R9 and in due course will come up with another 'best ever' - IMO ignore this, play any/many R9 replicas and evaluate them on your own terms - Your hands and ears never lie
That is actually the single reason why the entire vintage market stays afloat. Everyone can claim their product is the closest because there is no single correct answer. This leads to punters having loyalty to their own favourites, once they've spent a fortune on a bunch of similar but not identical products on the way.
If it was a simple cookie-cutter product somebody would've just made a perfect clone decades ago and the job would've been done.
You could doubtless find an original PAF that sounds exactly like a Custom Bucker and another which sounds exactly like an OX4, hence my slightly facetious original answer to your question.
The history and construction of those old guitars is a genuinely fascinating subject and I'm glad there are experts who obsess over the minutiae just like I'm glad there are specialists in ancient Minoan pottery - but there does come a point at which you have to ask yourself what you actually want from an electric guitar and how much money you have.
It is, when all is said and done, a crumbling old piece of consumer electronics made on a production line largely by semi-skilled workers who'd rather be fishing.
