Graphic and semi-parametric Equaliser pedals make sense if you require frequency-specific boosting.
Another useful option is an EQ or volume attenuator to reduce the volume in the loop (or a permanently on boost that you turn off). This can be really useful if you're playing a high gain part when the rest of the band are playing quietly. That way you can have three preset volumes for any given tone.
if if you already have a GE7 no need to buy anything else
i would also also say the buffer in the Boss is better than true bypass when you could be running 40 foot of cable in the loop
Just because you're paranoid, don't mean they're not after youStudio: https://www.voltperoctave.com
Use decent leads to avoid tone suck and you should be right.
