Just picking up different guitars and noodling on them doesn’t work for me if I’m trying to be accurate. Muscle memory kind of has to be re-dialed in a little
no, hangon, maybe my LP DC Jr is more angry and as nice but the PRS does more than just shout rude words at you...
Play it through a Tweed amp - then come back to us!
There are subtle changes your fingers need to make due to differences in fretboard radius, neck profile, neck width, neck thickness and taper and it takes a while for your hand to adapt without having to think about it.
There are some guitars that I can't get on with, but I would never describe them as 'comfortable' for me to play. The fact that you say yours IS comfortable, tells me this is not one of those cases
DO make sure the nut is set right, ditto the truss rod, and the action is not too high ( because those little and easily sortable things being wrong can wreck the playing experience) and persevere...I doubt you will regret it
