Nitro coming off
hotpickupshotpickups Frets: 1823
Is there anything I can do with the gunky/sticky nitro thats collecting at nut and base of my les paul neck. It's just wearing off the back of neck now and ending up at these locations. Something I can use to wipe it off maybe?
https://i.imgur.com/cMJ87Lr.jpg
https://i.imgur.com/8uKCH1j.jpg
  • OilCityPickupsOilCityPickups Frets: 10927
    Well nitro thinners will tale off the nitro ... but also effectively strip the neck ...
    Are you sure it's not just playing grease from your hands? That's seriously worn ... wow!
    You could try some virtuoso cleaner first and see if it is nitro or not..
  • meltedbuzzboxmeltedbuzzbox Frets: 10340
    Lighter fluid?
    What model LP is that?
  • hotpickupshotpickups Frets: 1823
    Yeah I've played it..... a lot over the years. Not wanting strip the neck but not wanting re nitro it either :( I quite like the bare feel
    1981/2 Standard I believe
    Lighter fluid?
    Hmmm not sure I want introduce any flammable liquids to it ;)
    Ok. Just presumed it was nitro residue but could be something other.
    edited July 2018 tFB Trader
    I get crap like that on my almost-bare maple tele neck ... disgusting as it might seem ... I believe it's a mixture of grease from the skin and atmospheric dirt! I use a tiny bit of white spirit to wipe it off ...
    eeeek really? What do you use to clean it off @TheGuitarWeasel ?
    eeeek really? What do you use to clean it off @TheGuitarWeasel ?See above lol ... white spirit
  • ICBMICBM Frets: 72864
    Serious question - are you diabetic? Your body may be producing acetone-related compounds, including in your sweat, which I think is one of the effects of diabetes. If so, this will attack a nitro finish.
    Whatever the cause, if it was me I would strip the whole neck up to the body joint and at least to the ridge of the volute, even if not the whole headstock. If you like the feel of the worn section, oil-finish the neck - maple is fine with this. If not, have it refinished with something that isn't nitro.
    edited July 2018
    No absolutely not diabetic. Ok I'll ask my nearest Luthier and hopefully re refinish it with an oil finish. Quite like to keep the worsens though as it isn't fake relicin'
  • sawyersawyer Frets: 732
    Strip it and leave a stinger at headstock end. Be cool!
    Stinger?
  • Adam_MDAdam_MD Frets: 3420
    edited July 2018
    It’s a guitar and guitarists are shallow bitches of course it’s purely cosmetic.
    Though I used one on a guitar to save the serial number etc a few years ago while stripping the neck.
  • KKJaleKKJale Frets: 982
    edited July 2018
    As recommended above... try to get hold of a bottle of Virtuoso cleaner.
    It's amazing stuff. It will not damage nitro, but it spirited away the ancient gunky heel build-up on my 330 when nothing else would.
    Not sure I can afford cosmetic enhancements ;)
