Cheap compressor reccommendations?
LongtallronnieLongtallronnie Frets: 1201
Been thinking lately that I could do with a compressor, something cheap, easy to use and fairly transparent. And cheap. Did I mention it needs to cheap?
  • steersteer Frets: 1196
    Mooer Yellow compressor. It's cheap, fairly transparent, and cheap. And it's nice and small, and quite cheap.
  • BeexterBeexter Frets: 614
    Biyang Compress X. Not necessarily transparent but a very good clone of the industry standard Dyna Comp but with a lot less noise and a very low price tag.
  • rossyamaharossyamaha Frets: 2462
    Pick up a Marshall one. They’re brilliant and cheap. Toured one for 6 years before the days of pedalboard builds and it never let me down. Still got it.
  • Ill second the mooer Yellow comp. Bats well above it’s weight.
  • munckeemunckee Frets: 12415
    Plus one for Edward the compressor, I asked on here and it was recommended, picked mine up from @grunfeld and use it loads.  Good range of compression available.
  • brojanglesbrojangles Frets: 362
    Thirding Mooer Yellow.
    Plus 2
  • I've got a Mooer Yellow comp you can have for £10.
    It had an intermittent fault where it wouldn't pass any signal. Strangely if you pressed down on the 2 small control knobs it would rectify the problem. My solution was to use a cable tie pulled tight around the casing over the 2 small control knobs applying downward pressure. Since I done this I haven't had any further problems.
    It may be an easy fix if your handy with stuff like that.
  • Thanks for the recommendations, the mooer looks worth a go. Thanks for the offer @kennedydream1980 but I'm guessing it's gonna be smd inside, too fiddly for me to work with!
