I’ve bought a jet city Amelia
timmysofttimmysoft Frets: 1962
never heard one, never seen one, ordered.
    Hope it lives up to expectation
  • newi123newi123 Frets: 891
    Interested to hear your opinion on it - what will it be used for?
  • FelineGuitarsFelineGuitars Frets: 11649
    Mostly heavy rock but I do dabble in a few other non blues related styles. I just thought for £400 odd quid it’s gotta be worth a shot, got the matching 212 too.
  • p90foolp90fool Frets: 31735
    Just no.
  • CHrisP86CHrisP86 Frets: 360
    Interested in your thoughts on this as well. Loved the Cornford MK so tempted by one of these.
    I own an MK50 and thought the same though according to others it sounds nothing like it
    Does the demo recording on this thread sound much like your mk50 @Fortheloveofguitar ;
    Link to my trading feedback: http://thefretboard.co.uk/discussion/58787/
    Once it arrives I’ll do some videos and recordings, I’m sure it’ll be pretty good!
    Afraid not :(
    I was due to buy one when the initial spec and hype were announced and was perceived to be a clone of the Mk50 MK2. While they look to be a great amp with a practically identical layout they sound little like the MK50
    I’ve owned a few cornfords before so hopefully I can give a decent comparison
  • vasselmeyervasselmeyer Frets: 3674
    WAY too many knobs...
    Took it to to rehearsal on Thursday, it’s pretty good!
    The only way I can really describe it is, it sounds like a cornford preamp into a jet city power amp, it’s certainly unique. I need to do a few valve swaps and I think it’ll suit 6L6 better and I need to tame the huge levels of gain!
  • english_bobenglish_bob Frets: 5181
    How's the effects loop? I seem to remember that really irritating German guy on YouTube having some problem with it...
    I wouldn’t know, I don’t use FX loops because I like any effects out front
  • grungebobgrungebob Frets: 3348
    That is an obscene amount of knobs!
  • Crazed_FandangoCrazed_Fandango Frets: 62
    edited August 2018
    Yeah, the FX loop on that video by Henning Pauly (EytschPi42) showed that the FX loop had an issue where it boosted the sound when any pedals in it were engaged.  A deal breaker for me as I use the loop for my time-based pedals and solo boost.
    Check out this video at the 16 minute mark
    Don't let your mind post toastee - like a lot of my friends did!
    It kind of is, but kind of isn’t, every one serves an actual purpose.
  • ICBMICBM Frets: 72751
    It would be useful to know if he had the Strymon set to true bypass - I assume the Keeley is. It sounds to me like an issue with an unbuffered (or very poorly buffered) loop which cuts level, so turning on the pedal then effectively buffers it and restores the level. If so, using a buffered pedal (or a buffer first in the loop) should cure the problem.
    It really baffles me why so many FX loops are so poorly designed. It’s not rocket science, but the number that do this sort of thing, or operate at the wrong signal level, or have poor parallel mixing which causes trouble with phase and/or latency, or are in the wrong place in the circuit (not after all the preamp distortion) seems to vastly outweigh the number which do everything right.
    What’s astonishing is that some of the very first amps to have loops - the Rivera-designed Fender Concerts - are still among the very best. If Rivera could get it right in 1982 almost working from first principles, why can’t modern designers?
  • I'm not sure it is a buffering issue; although the sound gets louder, it also becomes pretty gnarly.
