Once that's done, reboot (to get the lowlatency kernel running) and run Cadence; you'll need to configure your interface (usually just click Configure, select the interface from the dropdown, then set the number of inputs and outputs and configure the buffer for your desired sample rate and buffer size - it's all in there).# Fire up a terminal# Install KXStudio repositories# Install required dependencies if neededsudo apt-get install apt-transport-https software-properties-common wget# Download package file# Install itsudo dpkg -i kxstudio-repos_9.5.1~kxstudio3_all.debsudo apt-get updatesudo apt-get dist-upgrade# Install wine-rt, wineasio, cadence and any dependencies (this will install jackd as well)sudo apt-get install wine-rt wineasio cadence winetricks linux-image-lowlatency linux-headers-lowlatency# Install libpng12.so from Ubuntu Xenial - WINE needs the i386 version to install Native and you won't get icons in Helix Native without the AMD64 versionsudo dpkg -i libpng12-0_1.2.54-1ubuntu1.1_amd64.debsudo dpkg -i libpng12-0_1.2.54-1ubuntu1.1_i386.deb# Add your user to the audio group - *really important, nothing after this will work otherwise*sudo usermod -a -G audio <your_username_here># LOG OUT AND LOG BACK IN - OTHERWISE NOTHING WILL WORK# Install a bunch of Windows DLLs needed to make Native workwinetricks vcrun2013 gdiplus wininet# Now we can get started with the apps!# Just download the latest Reaper and Helix Native installers and run them! It's easiest with the VST3 version of Native, so select that during the installation process.
I'm currently running Reaper under WINE, and if I'm honest there's not a massive difference. However, some other plugins don't like lin-vst, hence doing it that way.
Instructions to follow later this weekend...
