Post the chord that is currently doing it for you!
124»
  • 19791979 Frets: 87
    @Sporky  is that one of the intro chords to Led Zep’s Ten Years Gone?
  • Sporky said:
    EADGBE
    X03230
    D=root: D6/9 / A?
    F=root: Fmaj13/A?
    A=root: A11(b13) ?
  • BellycasterBellycaster Frets: 5864
    Sporky said:
    EADGBE
    X03230
    You've got one hell of a stretch with that 10th fret on the low E.
     B)
    Only a Fool Would Say That.
  • HAL9000HAL9000 Frets: 9731
    edited August 2018
    Sporky said:
    EADGBE
    X03230
    Dmin2 - I only knew this as I occasionally play minor chords using the xx323x shape, something I first came across at a Robert Cray concert. I quite like the slightly ambiguous ‘not-quite-a-major-seventh’ voicing.
  • barry2tonebarry2tone Frets: 212
    edited August 2018
    Going between a C minor/major slide and G7.
    D     0/5/7 depending on where you want to move to.
    A     0/5
    D     5
    G     3 to 4
    B      5
    E     x
    to
    D      0/5/7
    A      0 as alternate
    D      3
    G      5
    B       6/5 to move down again.
    E       x
    Standard blues fare. Favoured A7th is
    D     7
    A      8
    D     8
    G     10
  • SNAKEBITESNAKEBITE Frets: 1075
    A minor with a bit of a flutter on the Bigsby.....
  • SporkySporky Frets: 28649
    Dunno; I think I heard it at the start of a Pale Saints song. That straight into x02120.
  • VibetronicVibetronic Frets: 1037
    this is my favourite chord ever, with either low open E, F# or G # as a low note:
    E - X
    A - X
    D - 1
    G - 3
    B - 0
    E - 2
    I quite like the movable shape below, you get a nice strumming pattern and slide it up and down the neck, it sounds great:
    E X
    A 10
    D X
    G 12
    B 12
    E X
  • JAYJOJAYJO Frets: 1527
    edited August 2018
                          B  1
                           O  2
                           R  3
                            I   4
                           N  5
                           G  6
    Sounds a  bit dreary but good for the Anne Boleyns
  • DefaultMDefaultM Frets: 7366
    My favourite is this
    022xxx
    I call it Big Dave.
  • A
    X02255
    edited August 2018
    Minor 9 chord...
    xx736x
  • PhiltrePhiltre Frets: 4175
    "CBA":
    E - 0
    A - 0
    D - 0
    G - 0
    B - 0
    E - 0
    (Can't Be Arsed)
  • 57Deluxe57Deluxe Frets: 7344
    not sure if you guys picked up on these but there are some bizarre fingerings going on in this vid. Also - see how many are totally over-complicated by virtue of not stopping and thinking about a shape that you already know and make and adapt up to... theC-D @21:57 being one as I ALWAYS insist my students learn to make the open D as a mini BARRE on the A and append to with finger 2...
    <Vintage BOSS Upgrades>
  • ICBMICBM Frets: 72542
    Philtre said:
    "CBA":
    E - 0
    A - 0
    D - 0
    G - 0
    B - 0
    E - 0
    Em11, also known as the Broken Left Arm chord ;).
  • guitars4youguitars4you Frets: 14331
    I like the horn section style  phrasing with this - In G but change as required - starts with the
     popular G9 and G6 slide
    E  12    then  10         then  7  and  5      then   3  and 1
    B  12             10                  8          6                5         3
    G  12             10                  9          7                4         2
    works in blues, jump jive, swing, rock n roll
    slide up or down - all interface as required - play with in the verse or add to you solo licks as required
    ICBM said:
    Philtre said:
    "CBA":
    E - 0
    A - 0
    D - 0
    G - 0
    B - 0
    E - 0
    I think I found out that that was actually a chord back in the day when I learned to play "Wild Thing"
