Instagram
Instagram
(formerly customkits)
the freezer thing is a bit of an experiment... it’s the first time it’s been empty in 7 years and it’ll prolly be full again by the weekend...
wont hurt to bung it in overnight!... see if it does work...
So there you go... you can get Day old nitro to check (providing you use my secret recipe before buffing and freezing )
the blood of virgins? unicorn tears?
Looks great chief what a job you've done in such a short amount of time. I assume missus poopot has paid for the stuff while acting extremely apologetically.
I showed missus munckee the picture and explained your wife did it, she said "wow you would leave me on the spot if I did that" and I said "yup" and we both stood there in silence for a minute each in deep thought...
Looking forward to pics of this one when the missus dumps it in tbe bath
Hahahahahahahaaha!... you owe me a mouthful of coffee for that one!!!!
She won’t be able to... I will permanently fix this tele to the back of her wardrobe door... to taunt her ever time she goes in there
new switch and pots arrived and glued together:
Mojo 59 relic set back in...
Gonna have some lunch now, bing some strings on it, give it a quick set up and crack on with some proper work!... video to edit ‘n all that!!!!
CHEATIN' FECKERS!
Edit**** plus fcs don’t have access to my pot of “green”
this body seems to chime a bit more acoustically than the last one... @customkits has that now so watch out for a “repair” thread at some point...
Fin.
Instagram
@poopot fine work sir
So warm dry air rather than heat, good airflow. Making sure the body is at the right temperature
plus the way it’s finished with minimal sanding and
Tcut is not the same as flatting out through the grades and machine buffing.
still would of been nice to share the technique if it’s that good.
it looks the part so nice work
