Does this Strat exist?
HootsmonHootsmon Frets: 16013
edited August 2018 in Guitar
Custom shop two tone (none of that red colour) 59 - 62 slab board rosewood neck
Med Jumbo frets
9.5 radius
nitro finish
tae be or not tae be
  • thermionicthermionic Frets: 9680
    It will if you ask (and pay) the Custom Shop to build it.
    That’s how it works, right?
  • BrizeBrize Frets: 5636
    I've got a 2-tone sunburst ash-bodied '62 Custom Shop Strat with those specs other than the board, which is round lam (which I prefer) rather than slab.
  • HootsmonHootsmon Frets: 16013
    Brize baby..... how come you prefer?
  • guitars4youguitars4you Frets: 14500
    It can be ordered - the nature of a Fender Custom Shop is to effectively build each guitar on such a basis - ie instead of building say 1000 Strats that are the same/similar, they'd rather build 1000 that are spec'd differently - e it neck profile, colour, pick-up option, wiring option, fingerboard radius, fret size and ageing process be it NOS, Relic etc
    So it can be spec'd - If you can find one on any dealers wall to your exact spec'd then fine and probably some luck required - The more you have a detailed vision of your needs, set in stone, then the harder to find that exact spec on a dealers wall
    No problem to have built - approx 6 months delivery and for now, without knowing a full spec sheet, then a guess-tim-ate is around £3k to 3.5k - Myself, Doug at Coda, John at Peach etc all do such orders, so we can all help etc if required
    any questions just ask
    This is very unscientific, but it sounds a bit more like a maple-boarded Strat but obviously with the feel of rosewood under the fingers. For me, that's the best of both worlds.
  • WhitecatWhitecat Frets: 5454
    edited August 2018
    There was a ‘59 “Thinskin” AVRI Strat run done for the US a few years ago - Daves Guitar and one other big dealer iirc - that fits that spec exactly except for the fretwire - they had 6105. It was USA, not Custom Shop... Google can probably turn up more.
    A few have turned up on this side of the pond...
    Does the guitar exist outside of the Custom Shop, other than the one above?
