Black Tube Screamer
darcymdarcym Frets: 1303
I've just got back from a period of working away, and had some discussions with others while I was away and got involved in a challenge.
I'm trying to find a tube screamer pedal in a black enclosure, but a really good one. Who makes a "black" tube screamer, I'm actually struggling to find one
  • ICBMICBM Frets: 72922
  • darcymdarcym Frets: 1303
    the TS5 was one I was considering as I remember someone having one in school. I remember them as "tinny" compared to the original, but I don't know the internals and how similar they are
  • Does it have to be an actual Tubescreamer, or is a tweaked version ok? I understand the Selah Feather Drive is a heavily tweaked tubscreamer-via-XoticBB circuit. It's certainly a good pedal
    They sound identical to a TS-9 as far as I know - the circuit is exactly the same. I haven't done a back-to-back test though - it is possible that component quality could make a small difference, but it won't be huge.
    The only real problem with them is the slightly flimsy jacks, but if it's going on a board it shouldn't matter.
  • prowlaprowla Frets: 4983
    $199 for a copy?
  • I believe this is basically a tube screamer but with added tonal tweakability and a noise gate to suit the metal brigade...
    found one in my drawer, I got the Keeley 808 in limited edition black a week or so ago, totally forgot about it. Sorry waste of time post. Although some interesting responses, so thank you
    so that surprises me as I love the TS9 more than the 808's I own, I don't care about the crappy case quality, I love the TS10 and that's made out of bubble gum and magic, however, the ones I remember where mega tinny, maybe that was the amps of the time, I'll certainly give one another go if I can find a cheapo one.
    I should have said "tube screamer voiced" basically "the tube screamer circuit in some form"
  • Black Tube Screamers Matter
  • EQD Dunes is black and white.
  • I did a series of videos on my YouTube channel a while ago comparing all the production ts pedals against an original 808. The shitty plastic ts5 was the closet to the original. Who’d have thunk it.
  • Racist
    certainly not I, but key to know, thank you
  • toadworks texas flood.
    edited September 2018
    The truth is, they all sound basically the same - in terms of the circuit. There is a difference caused by the chip, which is noticeable when the distortion is up full but - ironically given how they're usually used now - not at low settings.
    Otherwise, the differences between individual TS-808s, TS-9s, and TS-5s are certainly real but are to do with component tolerance and drift variations rather than the circuit itself. (It's true that the TS-10 is slightly different.)
    The TS-808 does have two different output buffer resistor values, but these don't actually affect the sound - you can fit a switch to prove that. So I don't find it at all surprising that an individual TS-5 might sound the closest to an individual TS-808...
