SOLD Mission Engineering Gemini 1 FRFR £649
guitarmansteve77guitarmansteve77 Frets: 151
edited September 2018 in Amps £
This is a powered flat response speaker for modelling amps like Helix, Kemper, Fractal etc.
Its very loud and looks more like a cab than a monitor.
It’s in excellent condition.
Gemini-1 is a 12″ full range digital amplified speaker with integrated USB and Bluetooth wireless audio for use with modelers and software based guitar systems
Construction is box and finger jointed 3/4″ void free Baltic Birch with black basket weave acoustic speaker cloth, chrome metal hardware and silver grill piping.
Mission EmPower Technology™ features multi-channel class D power amplifiers, active crossovers with variable EQ, and full range co-axial drivers, all designed from the ground up to work together as the perfect amplification solution for modeling systems.
The included studio quality digital audio interface features bit perfect class 2 stereo audio with selectable sampling rates up to 192KHz at 24bit. This allows you to play and record directly into your PC or Mac without any additional hardware. The EmPower EQ control allows blending between a flat or a more traditional guitar cab frequency response.
Stereo inputs are summed into a mono signal and output through the internal speaker drivers. Add a second Gemini, and PresenceDetect automatically determines the master/slave configuration and routes the stereo signals to the appropriate left and right units.
You can use Gemini almost anywhere in the world. Just connect directly to wall power wherever you are with a suitable cable. The included V-Lock power cable protects against accidental removal Power saving features such as a high efficiency power supply and deep sleep modes mean Mission Geminis use a fraction of the power of a regular amp.
https://imgur.com/a/aE8jdU3
