FS: Gretsch G6129 Proline Silver Jet - sold on ebay
Winny_PoohWinny_Pooh Frets: 7868
edited October 2018 in Guitars £
2006 FMIC model. This is the more chambered and vintage correct model (best stock Filtertrons), not the same as the earlier multi-laminate-neck solid bodies. Mahogany chambered body with laminated maple arched top. Fingerboard: ebony, 12” Radius (In reality closer to 10"), 22 medium frets and a medium/slim neck depth. Nut: Bone, 43mm wide, Machineheads: Grover Sta-Tite, Scale Length: 24.6' Two volumes, one master volume, 3 way selector & 3 way treble cut switch. (actually gives a slight mid/low bump too which is great with drive sounds)
Excellent condition. Has some small indentations on the low side of the back and slight surface scratches that are hard to photograph. No obviously visible dings or finish breaks/flaws as you can see from the side & back photos. Frets are even with a low action. IMO the best condition used Jet you could find.
Minimal essential mods are already done: new Tru-arc serpentune compensated bridge (original space control bridge included, plus truss rod tool and case key), Kinman treble bleeds on the volumes & a milder cap on one half of the treble cut switch.
Easy playing, stays in tune well and sounds really great. Selling as I prefer narrower necks.
PPG postage or meet in or around London,Berks,Herts,Surrey
Was £1650 now £1575
