70'S Strats, how big were they?
  • robgilmorobgilmo Frets: 3681
    I quite like the big headstock, I much prefer it to the little one, I think it sits better visually with the rest of the guitar.
  • DrBobDrBob Frets: 3012
    Me too, much prefer a big headstock
  • SchnozzSchnozz Frets: 2013
    +2
  • robertyroberty Frets: 10913
    Schnozz said:
    +2
    Same, and especially on deluxe Teles
  • JezWyndJezWynd Frets: 6147
    ICBM said:
    I have played many 70s Strats which weighed over 9lb, and I think a few over 10lb... the worst was a 1980 candy apple red 'The Strat' which felt like it was made from uranium or something - it felt heavier than a heavy Les Paul, but that may have just been down to expectation... we didn't actually weigh guitars in those days.
    I purchased a new telecaster Custom around 1980, it's the heaviest guitar I've ever held. Wouldn't surprise me if it was 11lb but as you say, we didn't weigh them back then. I actually made it heavier by installing a solid brass bridge that must have added another half pound. And it had zero sustain, the guitar was so heavy any plucked string got discouraged and died immediately.
  • boogiemanboogieman Frets: 12477
    edited September 2018
    ICBM said:
    Henrytwang said:
    We all hated the large headstock but I don’t think it added that much to the weight
    Not overall it doesn't - but it does to the headstock, which is important to the resonance of the neck and hence the tone.
    Yeah I  don’t get the hate for the big headstock either, I think they look fine. Likewise there’s nothing inherently wrong with the three bolt neck fixing. It works fine; it was the crappy machining of the neck pocket that went with it that was the bigger problem. The late 70s pickups weren’t great though and the cheese/metal mazak bridge was an abomination.
  • NPPNPP Frets: 236
    I actually like mine (late-70ish lefty), big headstock included, but not much is original about it anymore. It only sounded good though after getting the full treatment explained by @ICBM above - finish stripped, new trem, contours reworked to earlier spec. I think setting it up so that the neck sits flat in the (now lacquer-free) pocket, without using the tilt mechanism, did make a difference, too.
    I had that guitar for a long time (decades), so selling it was never an option, and being a lefty its value was questionable anyway, which made it easier to decide to modify it further (and take the risk of doing the job myself).
  • ICBMICBM Frets: 72922
    I forgot to mention that I lined the neck pocket on mine with veneers to make it a snug fit. I can’t remember if the tilt was necessary or not, but I don’t think so - remembering that stripping the Thick Skin finish allows the bridge to sit about 1/16” lower on the body!
