A selection currently available together with a brief summary of vital stats:
1. USA Custom Guitars - Strat style neck - Original Order invoice first pic (note, the Suhr peghead was changed last minute to a vintage Fender style) - this neck is gunstock oiled on the maple and has been stored unused for a couple of years. No string tree pre-fitted (staggered tuners used) and aftermarket bolt style inserts added for long term strength and stability to the heel screw holes by Steve at Manchester Guitar Tech (bolts included). Rolled edges. Tusq nut fitted by Steve @ Man Guitar Tech.
2nd neck up from the bottom in next pic:
2. Warmoth Warhead - Strat style neck/heel with Warmoth Warhead headstock, 3rd neck (middle) in the pic above - Ebony on Walnut, Warmoth 10-16" compound radius, side adjust and heel adjust double expanding truss rod on Warmoth 'Modern construction'
http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth Standard thin back contour
http://www.warmoth.com/Guitar/Necks/BackContours.aspx , rolled edges, gunstock oil finish to the walnut back, 1 11/16 nut pre-fitted with superb Graph Tech Black TUSQ XL nut, 6150 stainless frets, and no inlay on the fretboard, white side dots. See invoice below:
3. Warmoth Strat replacement neck - Macassar Ebony on Walnut - Warmoth 10-16" compound radius, side adjust and heel adjust double expanding truss rod
http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth 59 Roundback contour
http://www.warmoth.com/Guitar/Necks/BackContours.aspx , rolled edges, gunstock oil finish to the walnut back, 1 11/16 nut pre-fitted with superb Graph Tech Black TUSQ XL nut, 6150 stainless frets, and no inlay on the fretboard, white side dots. This neck is currently fitted to my number 2 strat and I will need persuading to part with it (money talks!). It is very very good and I won't let it go without persuasion! If someone would prefer the guitar as a whole again I
might be persuaded at the right price (whatever that is!). See invoice above and pics below:
Next 3 necks are all Warmoth but haven't looked out the copy of my order invoice yet - will post it up when I do.
4. Warmoth Strat Replacement - Pau Ferro on Goncalo Alves 2nd neck down from top in group shot above - Warmoth 10-16" compound radius, vintage modern construction with head stock adjust truss rod
http://www.warmoth.com/Guitar/Necks/NeckConstructions.aspx , Warmoth 59 Rounback contour
http://www.warmoth.com/Guitar/Necks/BackContours.aspx , rolled edges, gunstock oil finish to the Goncalo Alves back, 1 11/16 no nut currently fitted but your choice can be added as above. Standard 6105 frets.
5. Warmoth Tele Replacement - Goncalo Alves on Goncalo Alves 1st neck top of group shot above - this is a Warmoth '24 3/4" Gibson Scale Conversion neck', Earvana Compensated nut, rolled edges, heel inserts,
Clapton profile
http://www.warmoth.com/Guitar/Necks/BackContours.aspx , Gunstock oil finish, 2 x Graph Tech string trees, Gotoh Tuner reams, 6105 standard frets and 1 11/16 nut. No fretboard inlay, white side dots. Warmoth ‘Modern construction’ with side and heel adjust double expanding truss rod.
6. Warmoth Tele Replacement - Goncalo Alves one piece vintage style neck bottom of group shot above - Warmoth 10-16" compound radius, vintage construction with head stock adjust truss rod
http://www.warmoth.com/Guitar/Necks/BackContours.aspx , rolled edges, gunstock oil finish to the Goncalo Alves back, 1 11/16 no nut currently fitted but your choice can be added as above. Standard 6105 frets. This neck has a crack at the back between the headstock and the skunk stripe truss rod cover and needs some minor repair. I will post close ups of this tomorrow and offer it at a big discount as is, or will repair for a negotiated price.
Asking:
1. £250 200
SOLD2. £300 240
TRADED3. £350
4. £250 200
SOLD5. £200 160
SOLD6. £100 --
SOLDDiscounted prices + Your choice of delivery assume PPG.
The Wilkinson VS100 in black mentioned in the Warmoth invoice above is also available at £
60 + your choice of delivery and I have a second one in Gotoh's gun metal (they call it Cosmo Black but it looks like gun metal grey) also for £60 + delivery.
Thanks and let me know in pm if any questions. Cheers!
Also, the USACG neck is their AAA Birds eye maple with gunstock oil finish. Will post up further pics of backs tomorrow
edit: Gotoh tuners as pictured on #5 neck now Sold
These are reasonable tolerances relative to the original order but thought it worth mentioning. I have re-installed the nut on that neck. Rear shot as promised:
I'm most probably interested in #6 tele neck once I see the pics of the crack
cheers
G
all still available- the cracked Warmoth Tele replacement above has been estimated at almost certainly less than £50 to repair for anyone interested in that neck.
If anyone is close but undecided on any particular neck I will consider close offers ( except possibly the ‘59 Warmoth ebony/walnut on my #2 strat !)
