In excellent condition. Setup with 10s. Comes complete with hang tags and case, etc. Very similar to the PRS Silver Sky, which sells for significantly more without a hard case - and personally I prefer the feel of this. Lovely, smooth rock maple neck which is not varnished and very easy to play. Weighs just under 7.5lb.
Collect from Carlisle/Penrith area. Can meet within reason. Message me if you want it posted.
SOLD
Has very typical Strat-style bolt-on neck pocket cracks (which do not affect it and are unlikely to change).
Model: DC3
Top Wood: Alder
Frets: 22
Top Spec: Non-Figured
Top Grade: Non-Ten Top
Neck Wood: Rock Maple
Neck Carve: Pattern/Regular (Standard)
Fingerboard Wood: Rock Maple (non-figured)
Inlay: Ring Dots
Bridge: Tremolo
Color: Frost Blue Metallic
Hardware: Nickel
Treble Pickup: PRS Single Coil
Middle Pickup: PRS Single Coil
Bass Pickup: PRS Single Coil
Electronics: 5-Way Blade-switch
My band, Red For Dissent
I bought the NF-3 from the same chap, ended the same day; chuffed to bits with it. You'll not need much luck selling this, but GLWTS all the same.
