Hello to all on the forum.
I have an 80s Ernie Ball volume pedal & 'very simply' I want to reverse the taper exactly as the this article from Ingo Raven
here I have actually contacted Ingo a couple of times asking if he can mod my pedal, but have had no reply.
Thanks very much to the advice of Adrian at ThorpyFX I switched round 2 of the wires on the pot which reverses the taper, but, yes you guessed it. Now my pedal works backwards. I guess the next stage is to figure out how to change the string so that it pulls the pot in the opposite direction when working the pedal normally ?
I just wondered if anyone had any input at all or had done this mod themselves.
Thx in advance & here's a pic of the same era pedal I have.
Hours of fun .
Getting the spring and string arrangement hooked up correctly can be quite a faff if you haven’t done one before. You’ll need a hook of some sort - a scrap long thin screwdriver that you can bend the end of over is ideal.
