NAD: Guitar amp using single valve ... now with video ...
4114Effects4114Effects Frets: 3131
edited December 2018 in Amps tFB Trader
Always wanted to make one of these. It's a guitar amp using a single valve - the very cooly named compactron 6AF11. It's essentially an amp in a bottle - 2 triodes and a pentode output stage. Uses a groovy 12-pin base.
These are a little tricky to get right, having all the gain stages in one small valve, but I think I've nailed this one. The outcome was a real surprise, breaks up very smoothly and has a really nice crunch. Not much clean headroom to speak of, but plays very nicely with a guitar volume control.
It's not loud - 2w at max, but it sounds (and looks) amazing. I'm particularly pleased with how the ventilation/viewing hole turned
 I've built 4 more dinky enclosures the same so I might churn some out.
Pics for your delight...
0reaction image LOL 28reaction image Wow! 0reaction image Wisdom
  • Those plates are fantastic - the front name plate and rear "spec" plate. Do you make them yourself? Do you take orders? I could do with a custom faceplate for a modified Bandmaster.
    R.
  • 4114Effects4114Effects Frets: 3131
    R.
    My "real" job is as a graphic designer at a printing firm, so I design and print them myself :)
    R.
    Aaaaahhhhh - it all makes sense now! :)
    I'll PM you.
    R.
  • kreggskreggs Frets: 64
    Love your ideas. Looks great =)
  • bob21bob21 Frets: 170
    That is super cute! Looks awesome.
    What ballpark is the sound in?
    Hmm hard to describe. Maybe, mini-champ, but with smoother breakup and less rasp/fuzz. Definitely a blues/crunch amp with vintage tones. A lot of fun to play.
  • Jimbro66Jimbro66 Frets: 2431
    What a brilliant little amp. Is that a rear-mounted 2" speaker? ;)
    Haha, no - just a vent and viewing hole for the valve :)
    Damn. Sounds great! Would love to hear it if you do some clips!
  • LebarqueLebarque Frets: 3903
    Clips or it didn't happen!
  • ecc83ecc83 Frets: 1639
    edited November 2018
    Superb! There should be sheds of other, more common valves peeps can try. ECL80, ECL82,ECL83,ECL86 in accending order of power output and in some cases triode gain.
    You can probably find the "TV" version with a P prefix very cheaply. Same characteristics but a 150mA heater current and therefore odd heater voltages. PITA to used years ago but with modern 78 and other regulators, easy-peasey.
    Ooops! 300mA heaters.
    Dave.
    Missed one! The PCL85. Pretty kick'ass like an EL84 but was used as the field output valve in tellies. Not low distortion I wouldn't think so ideal for geetars!  Cheap too.
    Dave.
  • equalsqlequalsql Frets: 6164
    That looks fantastic. What a great idea.
  • frownfrown Frets: 32
    That is awesome! Gotta look into these.
  • prlgmnrprlgmnr Frets: 3992
    What's the smallest plausible speaker you could use to make a couple of tiny 4x(whatever) cabs?
    The smallest production guitar speaker I know of is a Jensen 6" ... Never been a massive fan of the sound though, a bit raspy.
  • amazing! would love to see a shot from inside!
  • 77ric77ric Frets: 539
    If you knock up any more I assume you plan to sell them, in which case how much do you you would sell these for?
    Looks ace by the way, need to hear some clips.
  • That's very cool.  Nice wrinkle-free tolexing around the vent hole as well.
    Heat, patience and a fair amount of swearing ...
