Does it matter what the back looks like ?
And if havent got one exactly the same , might you be able to use a similar spare iv got , heat up the shaft , get the button off, and stick it back on the epi tuner?
gu
For choice you’d go for a correct replacement right ? But practicality would suggest that function over form wins so if you do have something kicking about I’d deffo be interested !
Cheers
Rob
https://i.imgur.com/YMltPUa.jpg?1
Cover the postage and you can have the part for free.
I suspect that the OP is looking to confine the repair task to the removal of two small screws, a direct part replacement and refastening the screws.
