Development tools
To all you developers.
I'm going to teach myself python to create a web driven database application.
The mysql server and python/web server are remote.
Now rather than have lots of horrid putty sessions on my desktop and everything being vi/cli driven are there any good remote guis I can use to do the development on my mac. or should I just install an X client and use native Linux development tools just displaying locally.
  • randellarandella Frets: 4263
    MS Visual Studio Code is a good tool, but not sure it handles working on remote files.  I tend to work locally and then get the files onto a dev server, followed by the live server.
    Anyway it's a free download for Mac if you do decide you want to try it.
  • Avoid Eclipse
  • Avoid Eclipse
    Wish I could @Phil_aka_Pip :)
    “Ken sent me.”
  • dtrdtr Frets: 1037
    MobaXterm is still SSH (vi/cli) but avoids the "lots of horrid putty sessions" pain.
  • To all you developers.
    What's X windows ?  I only use the terminal :)
    @randella is correct work on your project locally then transfer the code via ssh. You could install visual code on the remote server then do ssh -X name@host then run the application from the remote command line.
    Python can be a right pain in the ar** (from a support install)
    You may be better to install Linux on a old PC and use all the development tools :)
    “Ken sent me.”
    edited November 2018
    Avoid Eclipse
    Aye. It's a flaky PoS with an almost totally opaque modus operandi.
    EDIT in my last job I used gedit, make, and debugged with printfs. It worked fine. In this job, remote gdb is the order of the day but I waste more time arguing with eclipse than getting the job done
  • Avoid Eclipse
    Eclipse + virtual conda environments yuk yuk yuk
    “Ken sent me.”
  • monquixotemonquixote Frets: 17670
    I'd just run the DB and web server locally for development and push it up as required.
  • wibblewibble Frets: 1110
    Just install MAMP  https://www.mamp.info/en/ ; and work locally
    deploy via git
  • Am going to try local python install (Mysql server will be remote) and Django and see how I get on.
  • PS I'm deploying to Google Cloud if that is any help as I work for them now.
  • I'd just run the DB and web server locally for development and push it up as required.
    This.
    Failing that...look up cloud IDEs...
    https://www.slant.co/topics/713/~best-cloud-ides
    <space for hire>
