What does "transparent" mean
  • I understand it to mean letting the natural sound of your guitar and amp shine through without colouring your tone.
  • JayGeeJayGee Frets: 1269
    deano said:
    Okay, so it isn't a feature of distortion characteristic, but rather of any EQ characteristics that occur alongside the distortion?
    Transparency is defined as how much or how little EQ change takes place. Okay, so not a post-modern redefinition (well, a little bit; just saying "doesn't change the EQ" would work!).
    Dynamics come into it too, some drives definitely compress a lot more than others. I agree it’s an oxymoron, but nobody seems to have come up with a better one word description of “doesn’t completely swamp the sound of your guitar with it’s own signature” so I’m happy to go along with it for the moment...
  • I've always interpreted a transparent sound to be one that sits in a mix (or overall band sound) without significantly masking the sound of other instruments. And that might vary depending on the sound of the other instruments.
    It's not a competition.
  • 57Deluxe57Deluxe Frets: 7348
    edited November 2018
    In a 'drive' context, Transparent means taking all the qualities of your existing signal and boosting it so that when it gets to the amp it pushes the amp so that you then get your existing qualities but with amp distortion on top.
    <Vintage BOSS Upgrades>
  • We've got at least three distinct versions of what it means so far. So I'd suggest if you read/ hear it unless they explain what they mean in that context it's essentially meaningless.
  • Cork sniffing needs a vocabulary. They are not hurting anyone. Leave them alone they are having fun.  :)
    Thinking about it, it does depend on context.
    hhawkins said:
    I understand it to mean letting the natural sound of your guitar and amp shine through...
    That's a good definition in the context of a drive pedal. As an example in this context, I think of an SD9 on a low gain setting as demonstrated by Oz Noy below:
  • deanodeano Frets: 622
    Sorry. Please accept my apologies I won't mention it again.
    But if you, or anyone you know, have been affected by this discussion, you can talk to trained councilors by calling 0800 VERTEX, that's 0800 VERTEX. Calls are free. Please, you don't have to suffer alone.
  • StrummyBrummieStrummyBrummie Frets: 266
    That made me chuckle. I have often thought though (and only half jokingly ) that some sort of AA style support group may well be beneficial around these parts ....
      The flood of happiness as the dopamine, endorphins and other groovy neurotransmitters combine when a pedal deal is done in the classifieds, or an eBay auction is won. Another hit when postie arrives heralding NPD and you take it out of the box and plug in. And more of the same for the 30 minute honeymoon of knob twisting, guitar swapping and amp switching.
    But then the come down..... As you AB with the pedal you bought last week, and the week before that, and the week before that. The slow but certain realization that were someone to blindfold you, you would be utterly unable to distinguish one from the other. Then the sadness, then emptiness, then the weeping ....
  • ewalewal Frets: 2623
    The only definition which makes any sense to me is the eq one. I can set my Rat up to very low gain but it's still not transparent because of the bottom end cut.
  • ICBMICBM Frets: 72731
    That would mean it can only apply to clean boosts, which is not at all the way it’s usually used - in fact it would then specifically not apply to overdrive pedals.
  • robertyroberty Frets: 10908
    Yeah same here. I suppose low clipping levels too
  • TTBZTTBZ Frets: 2917
    When I want something "transparent" i want it to just sound like a bigger/better/gainier version of my core sound rather than imposing much of its own character. The problem when you get a straight clean boost like an LPB1 is the bass flubs out and it all goes saggy/compressed and weird. So I prefer something like a Klon type which seems to keep the low end in check without the compression and sometimes excessive low/high cut of a TS. The Klon does add a bit of its own "special sauce" though so not completely transparent but it's nice.
  • TimmyOTimmyO Frets: 7590
    It means that marketing nonsense and internet received wisdom has entered common parlance
    Red ones are better.
  • NorthernStompsNorthernStomps Frets: 398
    Kinda this
    see TRUE BYPASS for a similar example
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • HattigolHattigol Frets: 8196
    Isn't the answer clear?
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
  • prlgmnrprlgmnr Frets: 3993
    This post transparently addresses your question.
    or did you mean when your Father becomes your Mother Mk2 or vice-versa?
