Combo amp valve rattle
TTBZTTBZ Frets: 2941
edited December 2018 in Amps
I've noticed a rattling coming from my amp (Marshall Mini Jubilee combo) which I'm almost certain is preamp valve rattle. It happened on my old one as well, V1 went microphonic. Before I replace it I wanted to know if there's any good way of preventing it happening again? Short of re-housing it into a head shell which I've been tempted to do for a while now!
I've seen the Eurotubes damper rings but do they actually work? https://www.eurotubes.com/store/pc/eurotubes tube damper rings.htm
If so, any UK based equivalent?
IIRC V1 has one of them metal covers on it (possibly where the rattle comes from?) - I guess that won't fit with these rings on so is there any downside to removing the cover?
  • ICBMICBM Frets: 72945
    If you remove the cover the amp will probably pick up unwanted noise - that’s why the cover is fitted.
    This is just a problem of putting valves in a box with a speaker.
  • p90foolp90fool Frets: 31869
    Those damper rings don't really do much to stop internal valve components rattling around in my experience.
  • RiftAmpsRiftAmps Frets: 3201
    A 10mm grommet 'threaded' onto the shield spring works wonders
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • ecc83ecc83 Frets: 1649
    Could actually be the spring that is rattling! BTW I have not found the cans do much if anything to screen valves but I suppose it depends on the amp layout?
    You will find some high temperature damping foam on the EL84 retainers of "our" 30&15W amps for just that very purpose.
    Dave.
  • TTBZTTBZ Frets: 2941
    @RiftAmps what size is that rubber grommet and where would I source something like that?
    Rift Amplification
    www.riftamps.co.uk
    Perfect, thank you!
  • mrkbmrkb Frets: 7004
    How hot do the 12ax7s get? Is there any chance that it could melt the rubber grommet?
    Karma......
    Ebay mark7777_1
    160 Celcius is the hottest bulb temperature for a 12AX7 type, but you won't get anywhere near that in a gtr amp. Grommets usually rated for a minimum of 200C.
    Rift Amplification
    www.riftamps.co.uk
    Thanks!
    Karma......
    Ebay mark7777_1
  • mbembe Frets: 1840
    If that fails replace the valve with a Tung-Sol Re-issue.
    edited February 2019
    Finally got round to fitting a rubber grommet as @RiftAmps suggested and it's made bugger all difference. Anything else I could try?
    @mbe - are the tung sols less prone to this sort of thing then? I think the stock Marshall ones are rebadged JJs.
    I don't get any rattle when the combo is plugged into a cab instead of the internal speaker btw. So I assume it's something to do with the internal speaker making the valve casing rattle still?
  • 57Deluxe57Deluxe Frets: 7350
    U2 dedicated a whole album to this issue...
    <Vintage BOSS Upgrades>
    I had rattle from my old jubilee too, I cured it by putting a gasket around where the amp chassis meets the cabinet. I just picked up some self adhesive rubber profiles off of the internet.
    Tung sol Reissue solved my rattly preamp valve in 2 combos where those rubber things didn't work. One replaced JJ, the other a Ruby (Chinese). Better tone and gain factor was a bonus.
