Allen key sizes for American Standard Strat?
My '89 US Strat is really hard going lately due to arthritis in my hands.
I thought that a change to 9's from 10's may help although I have never used 9's before.
I guess there will be less pull on the neck so some adjustment of the truss rod would be necessary along with the bridge.
My questions are:
What are the sizes of allen keys needed for the truss rod and bridge sections?
Will 9's be OK with the nut as is?
Thanks.
  • ICBMICBM Frets: 72648
    9s will be fine in the nut. If you're lucky, you might not have to adjust the other things either. If you do...
    Bridge saddles - .050". This is very small, and can be hard to find. If you're very careful you can make the more common 1.5mm or 1/16" smaller by grinding it on a sheet of sandpaper, but you need to be careful to keep it accurate.
    Truss rod and neck tilt - 1/8". DO NOT use a 3mm, which is the nearest metric equivalent - it seems to fit at first, but it's very slightly too small and will slip, sometimes rounding the inside of the nut and meaning it has to be replaced which is a serious job on a USA Standard, involving removing the walnut plug, replacing and touching up the finish.
    This is a fairly common issue - in my opinion a bad choice of part size since 3mm keys are very common for other guitar uses, eg locking tremolos, so a lot of people have them to hand.
    Get a set of imperial allen/hex keys.
    Agree with the ICBM ^ - 9's should be fine. If not, tune down to Eb like Hendrix et al!
  • NeilNeil Frets: 3641
    Thanks very much.
    As usual, quality advice on this forum.
    Don't fancy switching to a jaguar then?
    I must admit, a Jag with its 24" scale does appeal (My Gibsons play easier than my Strat) but I have always heard criticism of funny bridges, set ups and a tinny sound which has always put me off but they do look great and I'd like to get around to trying one.
    Think of it as an adventure!
    I had a go of the Johnny Marr jag and was well impressed. Pickups are well sorted, colours are gorgeous.
    To be honest, it won't be any easier to play a Jag because to make the bridge and trem work well you really need to use a minimum of 11s, and even with the short scale they still feel more like 10s on a Strat than 9s. You might be able to get away with 10s without it sounding thin if you fit a Buzz Stop.
    You could try a Duo-Sonic II or Musicmaster II though - super cool things, fixed bridge and 24" scale, and very cheap for a proper vintage Fender. The only problem is that most of them have the very skinny A-width neck.
    You can fettle a jag to work ok with 10's, come on...
  • FosterFoster Frets: 1100
    Get a set like this - it'll have every allen key you'll need.
    Years ago I bought one for the house and one for the garage - I got sick of having to play 'hunt the chuffing allen key' when working on stuff.
  • GagarynGagaryn Frets: 1553
    Yeah no problem. I even got away with 9s when thats all i had handy.
    Only if you like the feel of elastic bands for strings.
    It does work better with a Buzz Stop, though.
    Jags need proper strings ;).
    Neil is 76 years old, he needs spaghetti strings for his spaghetti fingers.  :-<
    This is unfortunately true! :-<
    Thanks for that.
    I see it has the elusive 50 thou size I will require.
    Understood, but a Strat with 9s or even 8s feels and sounds much more like a Strat is meant to than a Jag with 10s does... at least to me.
    My Jaguar is what got me into using heavier strings, because it really didn't work right otherwise.
    Thanks for the advice.
    I think 9's on the Strat is the way to go.
