Time Travel
Emp_FabEmp_Fab Frets: 24441
So... I worked out this afternoon that if you were on a plane near the international date line today, it was entirely possible for you to move from 2018 into 2019 and then backwards into 2018 again shortly after.
«13
  • Cool.
    Bye!
  • teradaterada Frets: 5114
    ;happy old year!
    Cool, but its not technically time travel though ....
  • Emp_FabEmp_Fab Frets: 24441
    I’ll add that this would be on a normal flight, not changing course either.
    No... I know it’s not time travel!  But... superficial time travel perhaps!
    Half an hour into 2019 and we're all on the board. Where's that plane emp?
    edited January 2019
    In reality, any plane that is near to a time-zone border today can experience this.  e.g. A flight heading West over Ireland at 23:59 will be in 2018 until midnight arrives, when it will be in 2019.  However, once it crosses the West coast of Ireland, it will move into the UTC -1 zone, which will be 23:XX back in 2018.
    Depending on the ground speed of the plane and the latitude it’s flying at, it will either end up back in 2019 if it fails to reach the next time zone within an hour, or - if it’s northerly (and fast) enough - stay in 2018 until it lands.
  • octatonicoctatonic Frets: 33846
    No, it is not.
    It is regular travelling.
    Shut up.  You’ve already pissed on one of my threads today!
    ...or last year, depending on how you look at it.
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • axisusaxisus Frets: 28341
    I think that was a year ago actually
    Well I apologised for that.
    Well, I didn't, but I meant to.
    I will... at some stage.
    Maybe.
  • martmart Frets: 5205
    It’s on a conveyor belt.
    I’ve just had another revelation!  Lines of longitude, and thus time zones too, converge at the poles.  Therefore time zones get smaller as you approach the poles - as does the tangential velocity of the Earth’s surface.  So, in order to keep up with the sunset at the equator, you would need to be travelling West at 1040mph.  At the (geographic) poles, this value is zero. (Don’t go off on one about the sun never setting etc - it’s an illustration of relative tangential velocity).
    Therefore....  assuming an aircraft velocity of 500mph, there will be a latitude where the Earth’s tangential velocity matches this - thus enabling the plane to remain stationary in time!
    In reality of course, the clocks would be going back in an hourly jump as each hour elapsed.
    Taken to the extreme, if you were to run around an object placed at either geographical pole, you would be traversing all time zones in a few seconds - forwards or backwards!
    It's called Time Zone travel ... my next door neighbours have just rolled up from Heathrow having flown from India. How many time zones did they fly through?
    Sort of, but not quite.
    This is the time zone map at the South Pole.
    When you get very close to the pole it is folded down to a single time zone (for obvious reasons).
  • I’m confused. Why would anyone want to revisit 2018?
    'Vot eva happened to the Transylvanian Tvist?'
  • scrumhalfscrumhalf Frets: 11346
    Time travel? Again?
    Didn't we do this next year?
    Is this like when superman flies really fast around the earth and everything goes backwards?
