1st things 1st I ain't much knowledgeable about Strats
I was at my Brother in laws today to check out his new birthday guitar, a nice new shiny Eric Johnson sig Strat
We were playing through a cooking crunch channel tone on the lead channel of his Express Boogie combo
Oh boy, you should hear his 2002 Les Paul in this channel..amazing punch volume and tone. Plug in the EJ Strat ( with same amp settings) and it is totally anemic by comparison ......half volume for starters. I have heard of folks gigging with a Strat and a LP and having to make adjustments to amp tone when switching guitar but this was a MASSIVE loss in volume and punch!
Is this par for the course or does the EJ guitar have mega weak pick ups or summit?
tae be or not tae be
Aside from the volume I want them to sound very different (as they should).
I've only played two EJ Strats as far as I know - one was really nice, and the other was the worst modern US-made Fender I can remember playing... it had all the resonance and tone of a wet cornflake box. Maybe even the worst Fender. I have no idea what was wrong with it, but if his is anything like that I can understand what you're describing - I hope it isn't.
It’s all about perspective - too much fucking perspective. As St Hubbins once said.
Humbuckers are basically two single coils stuck together.
Nothing hotter than a Pearly Gates.
But they still sound very different.
As someone pointed out, humbuckers are almost like 2 single coils together so it makes sense.
You can get Strat pickups that have as high as output as an average humbucker though, if you really wanted. Not sure it would ever sound like a normal Strat though. I think it's more common to either use a boost pedal or adjust the amp if someone is switching between the two on a gig.
I always use amp modeling and when I switch from LP to Strat I either adjust the gain on the amp or, more commonly, use a completely different amp model.
