Mixed fret wire widths
Does anybody have experience of using a wider fret wire on the first octave,
then  narrower wire -eg 6105-  above that ?
This, instead of the standard, ie  uniform wire throughout.
Obviously, the heights would be the same.
 I’ve heard that it’s occasionally done, the rationale being that you’ll get less ‘railroad sleeper feel’ over the wider fret spaces, whilst preserving good intonation , and room, in the upper register.
Any thoughts would be most welcome !
  • DLMDLM Frets: 2513
    @FelineGuitars sometimes does this, as does Siggi Braun. I'd love a try of either.
    The problem with narrower frets on the higher registers is that because they are closer together, they create this "steep-sided valley" feel, making sliding over them more difficult as your fingers will catch on them more easily. Wider frets have less steep sides, which makes playing smoother.
    That's the only potential issue I can think of. They will of course also wear faster, but that's not really a problem with higher frets.
  • FelineGuitarsFelineGuitars Frets: 11636
    I used to fit Dunlop 6100 frets 1-14 and 6105 15 and up.
    Both have a 0.055" height but the 6105 is narrower than the 6100
    In fact Stewmac wrote about me doing that in their trade secrets  section back in 1996
  • mbembe Frets: 1840
    Jake E. Lee's ESP signature strat had extra jumbo frets 1-12 and normal 13-22 to give more fretting room higher up the 24.75" scale length fretboard.
  • drwiddlydrwiddly Frets: 918
    I used to own an Overwater custom guitar that I had made in 1982. One of the features was what they referred to as 'Graduated Fretting' which was thicker fretwire (think Gibson) up to about the 15th fret and thinner (think Rickenbacker) from then on.
    I think it did make playing at the top of the neck a little bit easier but I've never owned another guitar like that and don't have a problem with the standard frets so I wouldn't bother.
  • octatonicoctatonic Frets: 33845
    One of my guitars has this.
    I have jumbo up to 12th fret and slightly smaller from 13th and up, I forget which exactly.
    Works fine.
