School Me on the Peavey Classic Series
  • I thought the Classic 30 was better than the 50 to be honest, mainly due to lack of extra volume control. I loved mine back in early 90's. the mid boost switch was a great idea, but unfortunately not foot switchable. I could get a very good approximation of a JCM 800 4010 combo, side by side almost identical, with mid boost in.
  • monquixotemonquixote Frets: 17662
    ICBM said:
    Lixarto said:
    I thought SRV died in 1990? August bank holiday weekend, in fact.
    My mistake, you're correct - which makes it a certainty that the 'Classic 50' he gave to Rodgers was actually the old plain Classic model, since as I've now checked, the Classic 50 was made starting in 1991.
    Is it possible that SRV might have had pre production models?
    They have always been described as 4x10 classic 50s to me.
    I wonder if had he not died they might have been an SRV sig model.
  • The original Classic series amps were solid state with valve power amps, similar to Musicman, with that old Series/Parrallel inputs. which I could never work out, sounded quite good as long as you changed the speakers.
    That would make sense actually as Nile also used to use the old Music Man hybrid amps.
  • Not conversant with much of Niles gear, did hear that he used very heavy strings, but was mainly rhythm work anyway. 12`s or something like that.
    A lot of his recordings are into the desk via a compressor, but the one thing you hear about him a lot is that live he tends to use a pair of Classic 50s given to him by SRV.
    I don't think he uses a lot of gear. He pretty much always plays the same 59 strat and I think he uses a compressor and a delay and thats about it.
  • ICBMICBM Frets: 72557
    This is an interesting mystery!
    Footage of him in the 90s is surprisingly hard to find - but there's this from 1996, which does clearly show modern-type Classic 50 410s -
    So looks like SRV may have had pre-production models.
  • EricTheWearyEricTheWeary Frets: 16299
    Footage of him in the 90s is surprisingly hard to find - but there's this from 1996...
    well, they recorded Live at the Budokan in 1996 and Bernard Edwards died that night so there's definitely nothing from the late 90's!
    I know - I knew that was Edwards' last performance, although I didn't realise before that he actually died the same night. I was hoping to find more early-90s stuff - best of all would be something from '90 or '91 with Classic 50s, which would prove it.
  • Saw satriani using a c50 live once with his sig pedals.
    Sounded amazing.
