Morning all
I've just purchased a switcher pedal to make my life a little easier on the old pedal stomping front.
I've been using the cheap Stagg cables for a while, but they do tend to break fairly easily and I was left in a bit of a pickle last week when they did,
Just wondering, for those that use switching pedals, what patch cables do you use? I've made some before with the solderless kits, and in all honesty I'd rather avoid that as they are a right faff. I can't solder either, so that's off the table.
Would appreciate your suggestions
Feedback can be found here http://www.thefretboard.co.uk/discussion/comment/908933#Comment_908933
If not, which switcher? The layout of the jack sockets will make a difference to what will fit...
Simply put bud, my plate is far too full to try add something else to it.
It's a disaster area DPC5
Which is why I said I'd rather avoid doing them
The solderless plugs are usually designed small for just such a situation, but pre-made patch cables are often right angled.
cheers for the advice bud, I'll wait to get the DPC5 first and then see what I'm up against
The other option, though probably a bit more expensive would be to get it all laid out, then measure and have someone make a bunch of cables up for you.
Theres some people on here I believe that can do that.
http://tinypic.com/r/2mgt749/9
squareplugs
These will fit in the back of the dpc if space is an issue and seemed to be much better quality than the cheapo pancake jacks. They are not cheap though
R.
Eqd Speaker Cranker clone
I can make patch cables for you (soldered) but personally I've always used Lava solderless for my pedal boards (I had a G2 for a couple of years).
R.
