Tokai what model is this MIJ
Th4fonzTh4fonz Frets: 266
  • Th4fonzTh4fonz Frets: 266
    edited January 2019
    Hi guys what model is this tokai first two numbers are 15 on serial says made in Japan on the back it's a satin finish back and top.
    Chunky 59 neck
    What's it worth?
    okai jap https://imgur.com/gallery/AvqTRud
  • The only way to know the model number for sure is to check the neck pickup cavity.
  • horseheadhorsehead Frets: 220
    What riff said
  • sweepysweepy Frets: 4209
    New or S/H ?
  • gordijigordiji Frets: 791
    Check the bridge cavity also , my LS 150 was stamped there. Also if you see a narrow long tenon joint in the neck cavity you'll know it's a higher end model. I have an LS 145S which isn't stamped in either cavity, it's an  R4 clonish, but i had it from new and that's what the paperwork says.
    edited January 2019
    Nothing in the cavity and seems like a 2015
    Used with non original pups downgrade in pups.
    Maybe a ls130f?
