The pedalboard is a bit of a revolving door of drive pedals- I change them depending on what I want to do.
I've got 4 big tubs full of pedals and they get swapped out from time to time.
Staples are the Wah pedal I've had since 1992 and I only ever use the Timefactor for my delays.
I was playing bass ten years ago and had no pedals at all, just an ART TubePac preamp/compressor in front of the amp.
I've still got it, plus one or two pedals.
Now -
This
and this-
Depending on what, where, who and how...
And now
I dtill I’ll have the Korg dt10, Marshall Guvnor, Damon fish & chips and Marshall regenerator though.
actually now I look st it, I can see how I ended up with what I have now.
Tim replaced Bad Monkey
zoom Ultrafuzz replaced Big Muff
POG2 replaced Boss OC2
Source audio EQ replaced fish n chips
Hardwire reverb replaced Boss FDR1
Bosd DD500 replaced Marshall regenerator.
The socks are still the same though.
Today, I still have the Valvetronix rig but it's been essentially retired from band-practice/gigging because of sheer size & weight and set-up time (there's also a 3-pedal mini pedal board that goes in the FX loop).
Shame really, because it still sounds great & is so easy to use.
But around 10 years ago I also bought a Laney VC30-210, (and later a Cub 12R and DSL401) and used this with them:
But today, I just use this:
or this:
And for mucking around at home, this (although I think I'm going to sell it)
And I keep this in my boot as an emergency back-up:
Now -
2019:
The lack of Amp modelling is exactly why I loved my ME-50 - it was a multi effects that just did effects.
Umm. Well I had a Danelectro Fab metal and a Boss oc-3...
But I only had 2 guitar leads so...
Nowadays its just.. more. Minus the Fury 6...
My grand scheme is to replace the Ds-1 and add a Strymon Bluesky at the end of the chain then rewire it with better cabling, possibly re arranging and making more space at the same time.. maybe I'll link an Ojai to the Zuma and have 5 additional slots to fill.. or maybe I'll call it done.. dunno.
If you want to sell the DS-1, PM me
I didn't have a board 10 years ago….only started like 4 years ago. This board hasn't changed in over 2 years + now, I can't think of any way to improve it for the features that it has for its size.
Everything is powered by a Cioks Pussy power, isolated.
I'll keep you in mind, though it could well be a way off if I do..
Ten years ago I was 21, I'd not been playing long, so I had a Digitech rp100
I've just commenced a huge clear out and simplification rig and my end result is these two on a pedal board:
Which goes into a....
However the sheer number of pedals that have come in and out in that time is utterly absurd considering ice ended up with basically a bigger model of the same thing...
soundcloud.com/thecolourbox-1
Two chains into an LS-2 & home made box. Got smaller before being broken up.
2012 Gorm board
Present setup
