The EQ Control alters the amount of gain applied at specific frequencies. Turning to the right will result in a brighter, tighter tone with more gain. Turning to the left will result in a fuller tone with less gain. You can use the EQ control to alter the overall voicing of the pedal. (Note: this a tweaked version of what is commonly know as the “Reutz” mod.)
The Clip Control alters the clipping threshold. You can use the Clip control to dial in the precise amount of compression and harmonic saturation. The more gain added, the more range this control has.
The Lonely Robot has a high input impedance and low output impedance. This makes it compatible with buffered effects in the signal chain. The Lonely Robot uses True Bypass switching.
http://www.magneticeffects.net/lonely-robot/
https://www.breakthemachine.co.uk connect@breakthemachine.co.uk
Always handy!
https://www.premierguitar.com/articles/28726-magnetic-effects-lonely-robot-review
