The problem with microphones is they work differently on different people.
It is as good a choice as anything if you are buying blind.
Usually I recommend a different mic for acoustic guitar (SDC) than I do a vocal (LDC) though.
One or two mics will get you pretty good results if you have decent outboard- mic preamps, compression/eq and converters.
Plus monitoring and acoustics of the rooms.
A lot of the time people try to buy their way out of trouble with a mic only to still try to record in an untreated box room through a £50 interface.
It doesn't always go that well.
If you have any questions feel free to ask.
The SE X1A (yes, really) has the same options and is also excellent, and significantly cheaper than both (about £85 new).
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
I've also got the Superlux E906 knockoff, which is probably the best value mic I've ever come across (albeit only for using with guitar cabs).
https://open.spotify.com/album/1pcKDSOLFk4dXDcNFNsN4e?si=KhHG26vgQeerEj1kF-177w
I recorded my acoustic using it here too if that helps at all:
