Push pull solid shaft pots in the UK??
Hello! That sounds like a "let me Google that for you" type of post but I can't figure this one out ... Does anyone know who sells 500k push pull pots with a solid shaft (6.35mm) in the UK?
CTS does one but I've only found it with US vendors... All I see in the UK is split shafts.
Thanks in advance!
Click here to see me butchering some classic solos!
  • gavin_axecastergavin_axecaster Frets: 527
    If you can't find any you can always use the split shafts with some conversion sleeves to accommodate solid shaft pots.
  • ICBMICBM Frets: 72709
    You really need to block the slot in the shaft even if you use those. A piece of cut-down pick of the right thickness is ideal.
  • PonchoGregPonchoGreg Frets: 764
    Thanks guys. Actually found an Irish seller on ebay - bloody pricey with shipping though!
