So the last couple of weekends has seen minor changes in a couple of guitars.
The LP Custom lost its pickup covers, and gained a set of Faber locking bridge & tailpiece. It also got a full fret level, which means it now places as nicely as it looks and sounds even better. And the reflector knobs are just plain nicer than the old top hats it had before.
![Image: https://i.imgur.com/tmDUTS4.jpg](https://i.imgur.com/tmDUTS4.jpg)
Then the ES-330 got plastic pickup covers and a riser for the bridge pickup. I've "relic-ed" the new covers a little bit to match the VOS finish, which basically just meant a careful bit of sandpaper and micromesh to get them worn or "sheeny" in appropriate places, combined with a few gentle whacks from assorted tools to make them look a bit more lived-in.
The upshot is this thing now SINGS. It was already a good guitar, but it's really fantastic now. Anyone with a nickel-cover ES-330 should consider this change immediately. I now finally feel like a *get* P90s in a way I didn't before.
The only issue is that I was intending to sell the 330 when I got the LP. Now I'm feeling the other way around. One has to go so I have a decision to make...
That's a very hard decision. Both are great, and very different. It all comes down to what sort of music you play and which you feel more comfortable with, probably.
P90 pickup height makes all the difference, get the height right - and I'm sorry, apart from the noise - I'd take one any day over a humbucker.
Interesting on the covers, might try that - thanks
I can believe the plastic replacements would make a difference, next step might be to find the paper thin covers the original old Les Pauls came with, they would tear if you looked at them funny.
Oh and that Custom looks stunning just as it is
Shim them up and let rip!
1 - No. don't be so silly. This LP is now aesthetically perfect.
2 - Yup. I'm leaning towards the 330 as it's a better couch guitar, is further removed from my other electrics, and the LP should be easier to sell. And I still fancy a goldtop and/or blacktop at some point, so this leaves that open for the future
Angela Instruments on Reverb. I originally found them searching for the shim/riser things then thought I would try the cover swap as well while I was paying for shipping. It's well worth trying. I had 2 Casinos in the last decade, including one with Creamery-rewound pickups. This was already a chunky better than either of them and is now a chunk better than it was new, and all better than the two lovely mid-60's ones I demoed in Nashville last year, that got me back on the 330 "thing" in the first place.
I can absolutely appreciate that now. Before, the neck pickup was good - and much better than the bridge pickup, which was too low despite being labelled as a different wind on the underside.
With the spacer and cover swap the bridge is now pretty much perfect, so I'd still like to raise the neck pickup just a fraction to get the outputs matched. I need to somehow get another shim about the thickness of a cornflake packet - I'm open to suggestions on that!
Run round the edge with a black marker after you've cut it out and it will look like very thin fibreboard.
Has anyone tried a locking ABR on a 330?
It's certainly very well made, for a start, and seems to give a little "more" to the guitar, especially when plugged in.
What I can say for certain, is that I like that the bridge and tailpiece don't fall off when you take the strings off. And I like that I can use the spacers under the tailpiece to have it raised just slightly for optimum string break angle, while also having it locked tightly to the body. On the bridge, I like that it's an ABR that doesn't need a retaining wire but also doesn't drop its saddles if you break a string.
Assuming I keep the ES-330 I'll definitely be getting that one a new bridge. The only question is whether to go for locking or not. Might have to search TGP... :O
As for the Faber thing, I assume it might make a good bit of difference on a hollowbody, but not sure whether good or bad. I guess the obvious option is to switch bridges with my SG's locking Faber and see if I can hear a difference, though again not a blind test. Will report back
I went up to 11's on that one yesterday (from 10's) , and it feels better with the heavier gauge. Haven't changed the bridge yet but still probably worth trying that as well as it's still a little rattly. Apparently the current one has titanium saddles, though I'm not sure what difference those make in reality??
