https://twitter.com/spark240
Reddit r/newmusicreview
got as far as downloading driver (called control centre I think) and Installed latest version of soft e-licence to activate Cubase LE 4
Installed Cubase LE4 and activated
According to documentation, I was then require to set up bus controls
First of all, CB recognised it was hooked up with Audiobox and displayed this in the VST screen, but when tried to switch to Audiobox on VST it fails to initialise.
It suggests re-installing driver, which I did, and then I lost it from the VST screen !!!!!!!
Don't want to fork out loads if the interface itself isn't compatible
Try this..https://www.presonus.com/products/Studio-One/get-studio-one
Its biggest drawback is that the free version of the software can’t load VST or AU plugins (you’ll need Studio One Artist with a paid add-on or Studio One Pro for that).
What does that mean in layman's terms?
Does the sound card work for listening to mp3s or youtube and so on if you select it in the Windows sound control panel?
If so, you can move onto Cubase and follow @Musicwolf's instructions to select the Presonus ASIO driver. If this doesn't appear in the menu, I would uninstall all the Presonus software, reboot the machine and then reinstall.
Next step (also in the Cubase Devices menu) is to go to the VST Connections page. This has tabs for inputs and outputs - on the output page make sure the correct hardware outputs are connected to the software outputs. You should then be able to play back the demo song, for example. Then on the inputs page, add a new mono bus for each input (probably 2 in your case), assign one to input one and the other to input 2 of the soundcard.
Nearly there! In the Cubase arrange page, right click and select "add audio track" and add two mono tracks. Make sure you can see the track inspector - there's probably a button near the top to view/hide this. In the inspector, select "mono in 1" as the input, press the record button and you should see an input signal in the mixer (F3 on the keyboard) assuming you have connected eg a guitar or mic to input 1 of the soundcard. If you press the yellow speaker icon, you should hear your guitar etc and see the signal on the meter of the record enabled track. On the second track, select "mono in 2" as the input and repeat the process for whatever you have connected to the second inout of the soundcard. If you want to record a stereo track, add it and select "stereo in 1 & 2" as the input.
It all sounds very complicated, but the basic setup should only need to be done once, and should take about 1/20th of the time it has taken me to write this lot - and unfortunately there is no plug and play solution, you have to do it the same for whatever hardware/software you want to use. It's worth persevering though, it's very high on my list of "funnest things you can do with your clothes on"!
I dont have any studio monitors at the moment, but I think I may have some sorted, along with an amp, as I believe the output from the Audiobox need an amplifier to go to passive speakers
https://www.ebay.co.uk/itm/Skytec-1000w-Set-Of-2-PA-Speakers-And-1000w-amplifier/202651737564?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055359.m1431.l2649&autorefresh=true
£70!!!!!
TBH, I bought them because they are cheap and LOUD!!!
I picked them up this morning, in excellent condition, still in their boxes, and I actually believe that they have been used only once. They do sound amazing though.
On the plus side, Prime has sorted out all my interface issues, almost as if it was 'plug n play'
Input, output and recording all working fine with guitar, going to have a play with midi keyboard tonight
