I got basically this result also. How exciting.
soundcloud.com/thecolourbox-1
This is where I currently stand. I've done this compass many times. I always seem to hover around the same place vertically, but I veer between the 4th square from the centre towards the left or the right, depending on whether I've smoked a joint I suppose!
Single coil on the left, HB on the right
USA made at the top
Korean at the bottom
Or Clean/OD and direct/pedals
Left Libertarian is a contradiction in terms, as you cant believe in freedom for some but not for others, it's simply not logical. It also tends to lead to a lot of criminality and corruption (see Spain, Portugal as examples)
Surprisingly accurate to where I would have put myself.
