I've actually had one before ....and jolly good it was too GLWS
I'll hit 'em !
With no tone control or eq isn't it tricky to get it 'dialed in' with different amps? Or is it designed as an appendage to LJ amps?
The overdrive side is where drive and saturation come in - and just allows more grind but with varying degrees of compression.
GLWS
(He said through gritted teeth)
