Gigrig QMX6 but 10 pedals..What goes in the loop?
Mark1985Mark1985 Frets: 234
So... This is my first switcher/looper and I'm not really sure which way to connect everything and what should go in the looper and what shouldn't.
My pedal order is as follows..
TC Polytune mini
Wampler Ego mini
Kingtone Mini Fuzz
Drybell Vibe Machine
Kingtone Duellist
Mooer Hustle Drive
Nobel's ODR-1
Strymon Lex
Source Audio Nemesis Delay
Strymon Flint
Any ideas?
Thanks
  • PhiltrePhiltre Frets: 4177
    edited April 2019
    Is there something that will always be on? Do you have any set to use buffered mode rather than true bypass? Any that are not used at the same time as others?
  • Mark1985Mark1985 Frets: 234
    The Flint is always on for the reverb and I tend to play with a light od on most of the time but only on edge of breakup. Not sure about buffers. Will check which ones have them.
    Maybe eliminate the Polytune and the Flint then. The main problem I have on my board is caused by having about 10 true bypass pedals. I have a buffer at the front. If I had a QMX6 I think I would put all the dirt pedals in it.
  • Winny_PoohWinny_Pooh Frets: 7837
    Put pedals you stack together in one loop and flint at the end. Polytune before the switcher.
