How would you describe the differences between the Tele bridge pickup and Strat bridge pickup?
(Real-world terms that specifically refer to something rather than buzz words like "twang" etc.
![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
From listening to various demos on Youtube, the main difference to me sounds like the Tele has more attack. Is this the main characteristic that makes the Tele bridge pickup so different to the Strat?
If you have both guitars, how would you describe the sound you're after when you go for the Tele?
The attack thing does make sense for country players often preferring a Tele - with it tending to be lots of notes plucked quite quickly rather than slow held notes with bends like in more bluesy styles.
Strat bridge - removes enamel from teeth
And I say this as a player that much prefers strats
Compared to an average weight Tele, a Strat is practically a banjo.
I did an interesting mod for @AuldReekie a while back - we put an Oil City Brassknuckle bridge pickup in his Blade RH4, which is basically two Fender-type pickups on a humbucker baseplate. The coils are identical, but splitting it to the one on the bridge side sounds like a Strat, and splitting it to the one on the neck side sounds like a Tele.
I'm convinced that through-body makes no difference whatsoever to tone. After all, the portion of string that goes through the body doesn't vibrate. It does make a difference to how the guitar feels though due to the break angle over the bridge.
I’d say the Tele is more percussive, whilst the Strat has more subtlety to it. Think Wilko Johnson (Tele) vs Eric Johnson (Strat).
The word "punch" is a word I've never really been certain what it means and, in fact, I think different people sometimes mean different things by it. I've been in to audio engineering way longer than I've been in to guitar (at least properly in to it) and the term is used a lot in that world.
I think it does kind of mean attacky in a way but also specifically low frequency or low mids. Is that what you mean when you say punch?
The reason for this distinctive tone compared to a Strat is a combination of factors centred around the bridge pickup: Firstly it's position further forward than a strat, secondly it's ferrous metal baseplate that increases the pickups inductance, thirdly it's the bridge 'ashtray' surrounding the pickup, thirdly it's the lack of routing compared to a Strat.
It looks like the pole piece for the high E string is about the same position on both but then the Tele pickup is more slanted so the low E pole piece is a bit further away from the bridge?
I have seen a drawing somewhere but I can't find it now. I think that's correct - the high E polepiece is in roughly the same position, but the Tele pickup is quite a lot more slanted, so the rest of the pickup is further from the bridge.
