I don't know how much experience of hardware mixers you have, some people prefer using faders to mix on but I've been doing it in software for so long that isn't an issue - however I believe the mixing workflow with the Presonus could be to use plugins as normal for processing then use the faders (and perhaps eq and fx ) on the desk purely for mixing, so it's kind of a hybrid process.
Another consideration is space - obviously the mixer option takes more, which could cause domestic friction depending on your circumstances.
When you record the band, how many inputs do you record at once? I imagine the mixer would be more convenient in that case, being easier to set up monitor mixes and having more mic preamps, however if you don't do that very often, the soundcard option might be preferable.
Sorry that's all not much help probably...
Space- plenty of that (+1 for the desk)
How many times do I record a live band - probably once a year (-1 for the desk)
Like you, I've done it all in the DAW for years now so certainly dont miss the feel of a proper desk.
Currently doing something similar, I use a little analogue desk for pre-production with synths and stuff plugged in then plug the bits I'm recording directly in to my current interface. It all works and does the job, just thinking of a revamp with more inputs and wondering which way to go.
Current thoughts are the presonus desk is probably not the best choice
Today, having changed my mid again I'm thinking:
Upgrade the bands XR16 for a XR18 which gives me a nice compact option that will be used for a live mixer with the option to multitrack record gigs/live sessions
Upgrade the UR22 to something better for home use, but keep it at 2 channels as that's all I ever use
Better option on the digital desk \ HUI route is the A&H QU-16 which can be had for around £800 used and features 18 in \ out, motorized faders for HUI, very good EQ and 4 effects processors
I tend to use QU16 for full on band projects and a simple 2 in 2 out interface for home, normally Avid as I like PT but there's loads of great interfaces out there very cheap
Feedback
