Hi all, despite trying to clear down my stuff I've been considering an amp again to double as my at home guitar noise maker and also as a monitor in case I get to play out in public anywhere. The Katana gets a lot of mentions as we all know but I've a few questions for those in the know.
I'll be watching some demos tonight hopefully which may answer some questions. I've got somebody potentially offering me one in return for my guitar for sale.
- Will I need to install Sneaky Amps in order to get a White Stripes style crunch rhythm tone (not the big muff sound)? And how does it respond to drive/boost pedals going into it on the Sneaky Amps compared to the proper amps? When I've heard it the clean has sounded more like Jazz Chorus clean and the Crunch has sounded more Marshall, so not sure how close one could get those to the "boosted to buggery" sound he uses.
- Can you do a line out with speaker sim on it?
- On the 50, it looks like switching can't be done with Midi, only with the footswitch. Should my Digitech FS3X work for this if switching mostly between two presets? (Google will probably answer this for me on the train home but thought I'd ask anyway.
- Is it easy to remove the Boss/Katana logos without marking it?
Mostly it'll be for home use or solo with no band (maybe backing tracks if I ever get my stuff together) so will need to sound fairly full and perhaps therefore does not need so much by way of "fitting into the mix" I think, so hoping that could be a good move.
Thanks all
I've never felt the need to remove a logo from an amp (even when it was a Solex 10W piece of shit) so I don't know - but it looks very well glued on. I wouldn't risk it. If you are genuinely embarrassed that it is a Boss amp then tape over it, I reckon.
They are great amps.
Yeah I am vain enough for the general ugliness of the amp to bother me, removing the terrible logo would at least just turn it into a black box
soundcloud.com/thecolourbox-1
I'm not really a fussy person when it comes to amp types. Even with my Helix I don't care what the name of the amp is, I just care whether I like the sound or not.
Sounds like you need to get to a shop that has one set up properly for tweaking with the software.
http://haveguitar.com/wp/2017/11/10/boss-katana-sneaky-amps-original-amp/
That being said I do have a massive itch to scratch and I do expect to be putting it up for sale purely because I've never owned a JCM800 and everyone needs a stupid amp at some point in their lives.
The emulated line out is a negative though unfortunately, I wonder if there's any way to turn that off anywhere?
I currently use a Digitech GSP1101 so no boutique amps to compare with - though having said that the Digitech replaced a Princeton Reverb and is much more preferable to that so maybe I'm cloth eared
It's the 50 I've been offered in a trade, the 100 is above what I'd pay for one anyway and I don't cope very well with volume so probably best I stay with the 50 (though could use the fx loop the 100 gives you to use it as a slave amp for something else)
Thanks all
Edit, inexplicabily it's now working, despite me changing nothing. Bizarre
I thought I saw some when I replaced my speaker anyway.
Respective weights are 25lbs vs 33lbs, but I’d like to be able to use the GA-FC and have the extra presets and the presence control. (although the Bright Onion 4-way switch would bridge that gap slightly...)
At the same time I need to be able to carry it about 1/4 mile to my mate’s house and still be in a fit state to play afterwards.
Estheroid’s blues junior must weigh 32+ lbs as it’s got a G12H in it. Maybe I should march up and down the garden with it a few times.
It's quite a compact box and it's balanced - it's not like the old Marshall combos where all the transformer weight seemed to be at one end!
1/4 mile walk should be fine for a strapping your man like yourself!
(Mine's now up for sale in the classifieds.. with the pedal. Ahem!)
They are loud amps, but the Master volume is well sorted. No silly volume jumps.
I'm often tempted to pick up a cheap, used 50 for home.
Re tones and Sneaky Amps; I've never touched it and I've had 3 Katanas now. My current one is still on V2 as I don't need to update it. I do have some presets saved using Tone studio but more often than not I only use the first 2, 1 is clean with a chorus and delay on it if needed, switchable from the GAFC, the other is a crunch channel, with an EQ tweak and an OD pedal and delay, again switchable. It took me all of ten minutes to set them up and they sound exactly how I want them to.
If I change from my Strat to the LP or vice versa, I make a slight EQ tweak and resave the patches by long pressing on the channel switches on the amp. Piece of piss.
Loud or quiet, as desired, light, portable and I can store the footswitch, power lead and guitar cables in the back. Walk in to a gig with a guitar on my back, another in my hand, and a 100w, fully giggable amp in the other hand. One trip from the car and no back issues!
