Aria Pro II SB600 Vintage Bass 1983 - Matsumoku Factory, Japan. £430 http://www.matsumoku.org/models/ariaproii/bass/sb/sb.html Black with a few age related dings from years of gigging activity. Passive electronics which have been tested through a small practise amp and a large trace rig. Neck is nice and straight and plays smoothly, having been set up professionally with flat wound strings. Obviously if you intend to use round wound strings you'll need to take into account truss rod adjustments. Not used any more so needs to be moved on. |
Thanks Anyway
