Nickel plating a chrome plated tremolo
 Sorry if that sounds really dumb but I have a rather wonderful Gotoh FST tremolo which holds tune much better than any other traditional tremolo system I’ve ever had.
Problem is, it’s chrome plated - and the rest of the guitar is ageing nicely...
How much of a hassle is it (is it practicable at all) to remove the chrome plating and nickel-plate the tremolo baseplate?
  • poopotpoopot Frets: 9099
    Would be easier and cheaper to sell the one you have and buy a nickel plated one.
  • gavin_axecastergavin_axecaster Frets: 526
    I don't think Gotoh offer trems in nickel. Even their relic vintage trem is aged chrome.
    Any steel that is chrome plated has a layer of nickel under the chrome (and a layer of copper under that). How easy it is to remove just the chrome layer I don't know. I would assume any chemical process would either strip the nickel as it strips the chrome or at the very least probably permanently discolour the nickel.
    Can chrome be removed with reverse electroplating?
  • jaymenonjaymenon Frets: 827
    Reverse electroplating - yes Gavin, I was thinking that too...
    The Gotoh has elongated slots in the baseplate rather than holes -  and the strings don’t touch the baseplate at all, hence the tuning stability
  • FunkfingersFunkfingers Frets: 14511
    Yes.
    The electroplating sequence is copper, nickel, chromium.
    A mild solution of hydrochloric acid will gradually remove the chrome layer, exposing the nickel beneath.
    I have successfully done this on cheap MIC bridge/tailpieces and expensive GraphTech String Saver replacement saddles for Floyd Rose. (The latter are not available in Nickel finish.)
