Can you tell string guage by eye?
  • vizviz Frets: 10758
    tony99 said:
    Fuengi said:
    Paul_C said:
    You'd be better off using the low E - there's a chance that a 9 might be nearer 9.5 and the same for a 10, but 42 or 46 would be much easier to decide on.
    I'm never sure if the low E is the vertically low e or the pitch low E?
    A cool trick for remembering is always to say 'low e' in a very, very deep voice
    Low - Low voice (lowing, like a cow)
  • fandangofandango Frets: 2204
    ICBM said:
    Which gauge would you want to use if there were no strings on it now?
    Use those.
    Except that if one’s tech skills weren’t up to scratch, there’d be an intonation problem.  :s
  • ICBMICBM Frets: 72839
    Unlikely, if it was set up correctly for any of those three string gauges before - there's usually little or no difference. And if it wasn't then you'd have to do it anyway.
    Maybe it seems easy to me because I do this stuff all the time...
    No, it really is easy. I'd agree that something like adjusting a truss rod if it's one with the nut in the neck pocket is something better left to someone who knows what they're doing if you're not confident, but anyone who can play an electric guitar can intonate it.
    As someone who is definitely not a professional I can confirm that both of those things are at least as easy as changing the strings.
  • prlgmnrprlgmnr Frets: 3998
    I can't gauge the gauge by eye so I got a gauge to help me gauge the gauge but the gauge only allowed me to gauge that the string whose gauge I was unsure of was either a 9 or a 10
  • AlnicoAlnico Frets: 4616
    Yes, but I see a hell of a lot of strings in all different gauges.
    Sometimes I custom order them as singles to make up a set of very specific gauges. When I do this, I do it just from memory of having seen, fitted and used that gauge in the past or if I've already used a plain 0.017 and I'm thinking about making it heavier or lighter, it doesn't take much to imagine what the new one would feel like, lets say a 0.019 or whatever.
    It's only familiarity, the same way a mechanic can tell you what size a bolt head is just by a quick glance and be right 99% of the time.
  • tony99tony99 Frets: 7169
    Whether it's deep or low doesn't matter.
    It's a moo point, like a cow's opinion. It's moo.
    Bollocks you don't know Bono !!
  • LestratcasterLestratcaster Frets: 1105
    I don't think I can, only by feel.
    I think an easy way to remember is just to remember that the vertical height of strings on a guitar in playing position is never mentioned.
    Low and high are used all the time in music, you'll never forget that. So just remember there's only one meaning of low and you'll know it's always the one you know definitely exists.
  • Simon_MSimon_M Frets: 542
    https://m.youtube.com/watch?v=fLwYpSCrlHU
    Typically called the 6th string, regardless of pitch.
    See that would actually confuse me, I'd always say the low E or if I was talking to someone who uses different tuning (I don't personally) I'd say something like "the string that's usually the low E".
    Don't get me started on "front and back" pickups lol
    Remember the phrase high 5; so the 6th must be low.
    Nice!
    Just need to remember Borat or David Puddy.
    High 5!
    So the 6 is even higher.
    Got it.
  • FuengiFuengi Frets: 2850
    It's not coordinated is it? What is standard tuning? EADGBe right? So surely the low E (the highest vertically) is the first string? Nope. It's the high e (the lowest vertically) which is the 6th when reading the tuning.
    Enough for you to want to gauge your own eyes out  ;)
    LOL.
    Brilliant !
  • hotpickupshotpickups Frets: 1823
    Probably couldn't tell by looking initially but as soon as I play them I'd know exactly. I usually play 10s but played a guitar set up with 9s recently and I was over bending out of tune like crazy. I could never play 9s, just feels like elastic bands to me now
