Problem with my amp - any ideas?
ToonToon Frets: 57
I have a Marshall 2061X.
Took it to practice last night and it developed a fault that has confused me.
I always plug into the lead channel and then jumper that channel across into bass channel = all is well in the world.
Last night - switched on (no standby switch on this amp) and nothing from lead channel at all. Swapped over to bass channel and all OK. Weird thing is that when I jumper the bass channel back to the lead, it does make a difference and the lead vol/tone knobs have a slight impact. So..........any ideas on what may be going wrong? Valves? Rectifier (or is it solid state rectifier on this amp?)
Thanks
I am not young enough to know everything
  • ICBMICBM Frets: 72574
    First preamp valve. Half is used for each channel, so one half is dead. Either that or a component associated with it has failed, but that's less likely - try the valve first.
    The unused channel controls do make a small difference because they're mixed passively with the used channel.
