Withdrawn: Kinman Impersonator Strat Pickups £180
jaymenonjaymenon Frets: 836
edited November 2019 in Parts £
Kinman Impersonator 56 Stratocaster Pickups (Knopfler Set)
£180
In beautiful condition - installed briefly
Black covers
[Imgur](https://i.imgur.com/cJxdv2D.jpg)
[Imgur](https://i.imgur.com/LorAvgC.jpg)
[Imgur](https://i.imgur.com/ABb5iiz.jpg)
Aged Stratocaster Pickguard £15 delivered
By Tricked Out Guitar
[Imgur](https://i.imgur.com/YThtxOB.jpg?1)
[Imgur](https://i.imgur.com/VEGoUsG.jpg)
New 12 Gold Filister Head Pole Piece Screws (for Humbuckers or P90s) £10 (delivered)
5-40 UNC Imperial Threads
[Imgur](https://i.imgur.com/cjelqvb.jpg)
SOLD
Wudtone 2.5mm Cutlery Grade stainless chromium steel Neck Plate and Stainless Steel Neck Screws £16
(delivered)
(Interestingly the screws have pozi-drive heads)
[Imgur](https://i.imgur.com/oalAOlQ.jpg)
Fender Neck Plate with Screws £5 (delivered)
The screw holes are actually a little rough - and I find myself wondering if it's really a Fender - but its thick, robust, and does the job...!
[Imgur](https://i.imgur.com/BDKneIf.jpg)
Oil City P90 Jingo Bridge Pickup (used) £50 delivered
[Imgur](https://i.imgur.com/SJJULC0.jpg)
Brand New Warmoth Stratocaster Neck Maple Rosewood
£260 delivered
I just don't have the time or energy to make another guitar - and I need to start playing the ones I have...
Standard Warmoth Thin Contour
10-16" Radius
1-11/16” Nut Width
6115 Stainless Steel Frets (.108" x .051" (or) 2.75mm x 1.3mm)
[Imgur](https://i.imgur.com/QKw5WkG.jpg)
Kinman Traditional Mk 2 Stratocaster Pickups K9 Harness Loaded Pickguard
£180 delivered
In beautiful condition.
The traditional Mark 2 pickups are brighter than the Mark 3 pickups (which were ‘dulled’ to make the Impersonator range of pickups sound brighter by comparison).
Fitted to a new pickguard which still has the cellophane wrapping on the surface.
The K9 harness allows some extra sounds (see diagram)
[Imgur](https://i.imgur.com/hFKwdX1.jpg)
Oil City Blitz Spirit Pair of Humbuckers (Brand New)
£120 delivered
Sadly I no longer  have the guitar they were originally destined for...
[Imgur](https://i.imgur.com/N10c3gN.jpg)
Monty's PAF Double Cream Humbucker Pickup Set
£185 delivered
Plenty of wire
It would be a simple matter to install a pair of covers if you so wish
[Imgur](https://i.imgur.com/Z7wSHw6.jpg)
Gotoh GE104B Bridge £16 delivered)
Tonerider AC2 Nickel Humbucker Set
in beautiful condition
£55 delivered
New Gotoh SD91 Staggered Tuners Nickel
I have one set - £35 delivered (one set sold)
[Imgur](https://i.imgur.com/2NOObER.jpg)
[Imgur](https://i.imgur.com/oY4TvWY.jpg)
[Imgur](https://i.imgur.com/6hUsT87.jpg)
Q-Parts Aged Jack Plate with Aged Jack Socket £20 delivered
[Imgur](https://i.imgur.com/WfuSTw4.jpg)
[Imgur](https://i.imgur.com/zTq1UYt.jpg)
[Imgur](https://i.imgur.com/WMItvki.jpg)
Warmoth Chambered Alder Stratocaster Body Sunburst Contoured Heel 3lb 4oz 1.47kg
£350 (plus delivery £10)
- Twin pivot posts installed by Warmoth
- Comes with Gotoh 510 (but suitable for American 2-point tremolo)
- well screened with foil and graphite paint
Purchased 6 months ago, but I have too many guitars and need to downsize - so technically it is 'used'
In beautiful, beautiful condition - as illustrated in the pictures.
3lb 4oz
Chambered Alder
Black-Red-Yellow Sunburst
Rear Routed (with rear cover and screws)
Contoured heel for improved upper fret access (see picture 8)
Tremolo locking studs installed by Warmoth
Cavities screened with graphite paint / copper foil
Withdrawn
Lightly Aged Nickel Gibson Les Paul Aluminium Stop Tail Piece £30 delivered
solid Ash body 3lb 5oz
£170
https://imgur.com/a/FOlvRIn
  • dallcorpdallcorp Frets: 139
    Pm Sent
  • algroves1algroves1 Frets: 17
    What resistance are the Monty’s please?
  • jaymenonjaymenon Frets: 836
    Montys PAFs DCR
    Bridge: 7.71kΩ
    Neck: 7.30kΩ
    Bump
  • victorludorumvictorludorum Frets: 1026
    Would you split the Blitz Spirits? if you will, is the neck in the 7/7.5 region?
    I’d certainly consider it, though it would be a bit simpler for me to sell them as a matched pair...
    Anyone interested in the Blitz Spirit Bridge pickup on its own...?
    Bump - new items added
    Bump
  • GrangousierGrangousier Frets: 2644
    Are the Monty's pickups a) two-wire; b) four-wire; or c) already sold?
    Monty's already sold...
    Bump
  • Bump
    edited October 2019
    Faber ABRL-59 Tone Lock Bridge ABR-1 Style (Aged/Relic Nickel). £45
    I bought it but never wound up installing it - so pretty much new (but Aged / Relic)
    Comes with two pairs of sleeve nuts, inch and metric.
    So usable for both original GibsonTM ABR-1 bridge existing posts (Inch thread) and import 4MM posts equipped guitars (Metric thread), or, using the optional Faber® E-Sert, ESWKIT, BSWKIT, NSWKIT or iNsert for many Epiphone, Tokai, Ibanez and other non-USA made guitars using a Large Bridge Post system.
    Also have a Gibson aged Tail piece £20
    [Imgur](https://i.imgur.com/Ymwo2GI.jpg?1)
    Bump
    Bump
    Bump
