Good quality cheapies
  • 57Deluxe57Deluxe Frets: 7343
    edited August 2019
    5 students at different times bought Pacificas and all of them were horrid sounding and had sharp frets and planky/buzzy necks.
    Andertons push them hard to beginners...
    <Vintage BOSS Upgrades>
  • SchnozzSchnozz Frets: 1953
    I haven't found anything that takes my fancy yet - I don't the neck profile on Pacificas unfortunately (too wide and thin front to back)
  • Dunno if it's been mentioned but there is a Epiphone LP special style thing with 2 single coils in, it's £98.  Never played it so couldn't comment on quality but otherwise, but an encore strat on eBay for £20 and deck the term if it's a problem.
  • 5redlights5redlights Frets: 317
    See if you can get a G&L fallout tribute second hand somewhere, that'll be around £200 used. Excellent guitar. Humbucker in the bridge so you could either split it or swap in a HB sized P90.
    Please tell me you're joking.
    I started out on an Encore Strat & it ALMOST put me off playing guitar entirely. Buzzy, wouldn't hold tune, sounded thin... Just awful. Even a proper set up merely elevated it to "crap".
    In 2019 there's simply no reason to subject yourself to that when a decent guitar has never been so affordable.
    Buy a Vintage/Harley Benton/Squier and save yourself a lot of disappointment.
  • mbembe Frets: 1840
    Encores just need setting up properly with new strings and a pickup swap, then they are every bit as good as Masterbuilt Custom Shop Fender (allegedly).
  • OilCityPickupsOilCityPickups Frets: 10560
    I remember trying to 'set up' an Encore 'Strat' for a student when I taught guitar. It has a dreadful locking Floyd style ... super cheap pot metal bridge similar to those fitted to Marlin guitars ... a horrible plywood body, nasty ceramic pickups ... it was about the most disgusting pile of junk I've ever worked on. Blurgggghhhh
  • crunchmancrunchman Frets: 11459
    I picked up a 3/4 sized Encore for my daughter.  Played alright when I first got it.  Little later everything has moved around.  Had to shim the neck, shim the nut, and the first fret has lifted so it buzzes something chronic.  Think the bridge is in the wrong place as well.  From memory, I couldn't get the intonation right.
    They are awful things.
  • igotgasigotgas Frets: 16
    I'd say a Pacifica is a good solid single coil guitar for the money.  Well put together.  Also the Squires, just watch the Affinity series (I think that is the one).  There is one model that has incredibly thin frets.
    I can't remember if it was Encore or a brand from the same price range, but I tried to set up someone's guitar and it literally didn't have a truss rod so couldn't even set it up properly.
    Is there any guitar in that price range that wouldn't have problems like that?
    I wonder what the lowest price a guitar is that can be free of any problems.
