The cricket thread
199100102104105266
  • RandallFlaggRandallFlagg Frets: 13944
    edited August 2019
    scrumhalf said:
    We've dried up the runs but aren't bowling enough wicket-taking balls. Aussies seem to be happy not scoring, compare that to our batsmen who seem to want to hit the cover off the ball after a few dots.
    Proper Test batting, block and leave in the tricky periods, keep patient and then put the bad balls away when the conditions change. The runs will accumulate.
  • scrumhalfscrumhalf Frets: 11314
    Rain, and probably for at least the next couple of hours.
    Bah!
  • HeartfeltdawnHeartfeltdawn Frets: 22177
    From one of the Crizbuzz journalists:
    "This is why England shouldn’t be trusted with proper quicks Australia’s pace collective bowl to standard fields knowing speed causes misjudgements in traditional areas (outside off, even standard set-ups). England have a leg slip short leg, not-so-short leg, catching mid on..."
    A pitch like this, a climate like this, you don't have to reinvent the wheel. Look at how Hazlewood bowled first up.
     2 wickets since I typed my pessimistic diatribe above! I should be pessimistic more often. =)
    I'm on the radio today, so no Sky - But it sounds like an initial poor opening spell by our bowlers - Archer looks a big prospect, but he needs to tighten up his line/length, but hopefully that will come - Early days for him, but already you have a feeling we are putting all our hopes on him
    Horses of courses - the Cricinfo article on why Pattinson got dropped out for Lords and Hazlewood came back in shows the level of thought Langer and his team are putting into all of this.
    https://www.espncricinfo.com/story/_/id/27394783/cherry-ripe-josh-hazlewood-brings-peak-precision
  • earwighoneyearwighoney Frets: 3497
    Joe Root seems to have learnt from the Alistair Cook school of captaincy...
    It's quite incredible how easy a ride the both of them seem to be given by commentators whilst the test matches are taking place.
  • NiteflyNitefly Frets: 4924
    Comment from the BBC live text page:  "Why don't we play cricket in the summer?"
    All fears, doubts and frustrations aside, England did well to get 3 wickets this morning. The bowlers will be fresh tomorrow after those relatively light duties. Game is still winnable. If England can get another 3 down fairly quickly then Jofra could bounce out the tail and it is possible Steve Smith could be choked for partners and with some good fortune England could go back out to bat with a lead.
    Alternatively...
  • JalapenoJalapeno Frets: 6393
    Sky don't hold back.
    Feedback
    Since Duncan Fletcher, who worked with his captains, we seem to have had a succession of captains who have worked for a coach.
  • guitars4youguitars4you Frets: 14304
    Just seen a load of Stats on Sky regarding S Smith
    Deliveries on target and his strike rate is over 120 - 97% of these are on the leg side - That is some statement
    Deliveries not on target, all down the off side and his strike rate is around 30 - with only 3% of runs on the off side
    So line, length outside the offside is required and starve him - Obviously you can sneak in the 'surprise' delivery - And make Smith step out of his comfort zone
    Barely seen a yorker to him - barely seen a slow ball to him - So no variation, other than a few bad balls
    Maybe it is not as easy as above, but surely it beats feeding him his stable diet
  • crunchmancrunchman Frets: 11460
    Bit worried they are going to over bowl Archer and run him into the ground.
    edited August 2019
    I've not seen such aggressive bowling from and England player as this from Jofra Archer, 95-96mph, a battered and bruised Steve Smith taken off injured after being hit hard twice.
    It's dirty, raw and thrilling, no-one wants to see a repeat of the horrific fatality of Phillip Hughes but to see an England bowler serving up real pace bouncers to the Aussies instead of the other way around is refreshing.
    England are bowling well and keeping Aus under control
    Agreed, but he still seems fresh after this many overs. Get the new ball and give Broad & Woakes the next 10 overs.
    IMO after reading Langer's comments regarding Archer earlier this week they gave the impression they weren't taking his abilities seriously and there's a chance they weren't respecting Archer at the crease, which can be a very dangerous thing to do.
    Blimey, Smith's coming back out.
    Bring Jofra back on?
    Yep, keep the foot on the throat until it's dead. That would be the Aussie way. Does Root have that ruthless streak?
    edited August 2019
    the pre-Ashes hype over Archer has been justified. He brings a new dimension and has had the Aussies bent sideways. He has potential for game changing spells, and England will need them to get this series.
    This late on day 4 with 2 innings left I can't see a result here but it's been good cricket.
    First innings lead of eight. Four sessions, two innings.
    Could be very tight.
    Jason Roy - don't repeat your first innings effort.
    Unless Aus now blow England out in a session or 2!
    edited August 2019
    Roy out for 2.  He's shaping to be the very worst of the all the terrible openers England have gone through recently.
    Now Root's out first ball.  Awful, awful, awful.
